Thread: re-spraying
    Regular Member WKD-mcc's Avatar
    glenrothes
    Default re-spraying
    am looking to c/c the chrome boot strip and my v from the grille,probably a daft question but jsut want to make sure,are you better off c/c them indoors or would it be ok to do it outside in my garage,it'l be rally cold though so am thinkin probably not.
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    I would do it in the garage mate, you don't want your house stinking of aerosol paint!!
    You could always take it in after to let it dry!!
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    when I tried spraying in the cold a few weeks ago the paint went a matt finish instead of gloss and had to use laquer..if I were to do it again I would do it in a heated enviroment
    glenrothes
    well when i done my side repeaters they the laquer on them went a little bit misty,but they turned out ok when i had a look the next day :|.just not up for the chance of havin to rub it down and buy more paint.al maybe give the strip a try and see how that goes but if it turns out bad least its not the both of them that'l be mucked up.
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    to cold in this weather to paint it will just Bloom you need heat and dry weather
    Surrey
    Can you heat the garage? Even so the air is damp at this time of year.
    I think I would wait for warmer times then do it in the garage.
    glenrothes
    thanks for the hepl guys,that was where my thoughts were leading to the most,think al leave it the now cheers
  1. Spraying
    By BigWilko in forum Bodywork & Interior
    Last Post: 13th February 2012, 13:51
  2. Spraying
    By signumboy in forum The 'Off Topic' room
    Last Post: 22nd August 2011, 22:40
  3. how much for spraying?
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2011, 13:16
  4. spraying
    By WKD-mcc in forum Styling
    Last Post: 17th April 2009, 15:48
  5. need spraying
    By wanna veccy in forum General Chat
    Last Post: 30th April 2008, 17:05
