Thread: amp power feed
    birmingham
    Default amp power feed
    trying to fit power amp in boot- 1.where is there a permanent live in the boot 2.where can i pick up from a speaker to feed the amp
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    anyone id like to hear about this myself
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    1.You have to take the live from the battery and run cabling through under the sills in side easy to take off using torque screw driver and the earth can get secured from the boot remembering to scape paint so you get a good connection.
    2.A ny good car audio do them or there's helfrauds.
    lanark
    Year : 2012
    Mileage : 9k
    cheers thanks for pm
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    There's a 40 amp feed in the rear main fuse box, the slot below the big orange blade fuse in the rear most fuse box.
    That works out at about nearly 500 Watts, if that not big enough, then you will need a dedicated cable from the battery, fitting a fuse would be a good idea close to the battery connection.
    lanark
    Year : 2012
    Mileage : 9k
    i'll need dedicated the amp is 600 watt
    Edinburgh/Catterick
    Here's a couple of mine as promised
    Attachment 19552
    live feed from bty
    Attachment 19553
    where the cable is feed into car
    Attachment 19554
    back of the stereo
    Attachment 19555
    the amp fitted
    Attachment 19556
    and the rear fuse box
    hope this helps you's out
    Edinburgh/Catterick
    heres the sub
    Attachment 19557
    sub amp and 6x9s
    Attachment 19558
    and the stereo fitted
    Attachment 19559
    now attached second amp and is on back of the sub.
    lanark
    Year : 2012
    Mileage : 9k
    very nice mate hopefully i'll have pics of mine next week sometime
  1. Looking for a 12v feed
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2012, 22:46
  2. Electrical project - Power feed
    By MrDerv in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2012, 00:34
  3. alternative power feed to 12v sockets
    By Vecmaniac in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 19:08
  4. head unit power feed????
    By jonny_adams60 in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2011, 17:52
  5. 12v feed
    By decks in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2010, 18:24
