Results 1 to 10 of 11
Thread: colour coded V grille
    Regular Member chris_1d's Avatar
    Cambs
    Default colour coded V grille
    Hi guys,
    If I want to colour code the front V grille, do I need to buy a new V, or can I sand down the chrome one and paint that?
    Thanks in advance!!
    Chris
    VOTING UKIP IN AVELEY
    5 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    yep just sand down and paint your original
    Sunny Dartmoor
    Newcastle under Lyme
    May seem like a stupid question but whats the best stuff to spray with ie cans of spray or airbrush and where can I get paint from?
    Cambs
    I've bought primer and paint from halfords....
    Not sure but you may need some lacquer to coat and protect it after
    Cambs
    Forgot that bit!
    Cambs
    I have bought grey primer and my black saphire paint. I hope I got the right primer??
    Will pop to halfords and get the laquer!
    Is the V grille separate to the grille itself? I was looking in ebay for a grille to practice on first, but as mine is an SRi, do I need an SRi grille or will any V grill fit?
    From model painting I think primer is primer. I know you can get different colours but that only helps if you miss bits so you havent got white showing through.
    Enough coats and making sure you do a good job will more than suffice
    Regular Member shan's Avatar
    You can remove just the V from the grill. Best to remove the bumper to avoid braking the clips.
    Have a look at the picture's in this thread and you can see the V removed from the grill.
    http://www.vectra-c.com/forum/showthread.php?t=63993
  1. Colour Coded V Grille
    By bobmcn in forum Styling
    Last Post: 6th April 2012, 06:31
  2. Colour coded grille
    By paul_sri150 in forum Styling
    Last Post: 2nd May 2010, 19:03
  3. Colour coded grille or not?
    By george1987 in forum Styling
    Last Post: 25th March 2010, 07:56
  4. V grille colour coded
    By sri22dti in forum Gallery
    Last Post: 5th December 2008, 00:03
  5. Colour Coded Grille
    By siross in forum Styling
    Last Post: 28th November 2007, 14:08
