Thread: front springs
    lanarkshire
    Unhappy front springs
    fitted new front springs to my sri 150 along with new discs n pads and new front hub (sensor knackered ) thought hmm looks to be sitting up went back to vaux parts centre and asked to check correct springs lo and behold wrong springs
    new springs wont be in till tuesday not a happy chappie
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i would give them the bill m8, do you know a mecanic friend that can knock you a recipte up?
    Quote Originally Posted by big rich View Post
    Talk to someone a little higher shall we say, no way.
    birmingham
    Engine : 3200
    Quote Originally Posted by Tadpole View Post
    yes thats what i ment
    lanarkshire
    as a diy job would feel unsure about what sort of recourse I have .asked about difference of price for correct springs told not to worry about that we will give you new springs change them and bring back wrong springs no extra charge for correct sri springs
    Quote Originally Posted by iceeee View Post
    Itís not just a wrong set of springs. What about your time & a double job hire of equipment x 2 time off work & now you have to do it all again. Talk to the manager & say this is not on, travel to & from the place. Replacement springs plus what else do you need, think of something a set of bulbs minimum type of thing for the hassle. It would be good if there were a queue behind you, just think whatís going through their mind. In fact draw their attention to it, I would. He may suggest they do it for you. Thatís fine but you need the use of a car to get to work. Good Luck
    May 2006
    scotland
    Suppose thats one advantage of entrusting work to a Garage, at least they'd be responisble for fixing it. But nevertheless, gutting.
    Regular Member rosssri's Avatar
    S.Lanarkshire
    How do you disconnect the clip that holds the flexi hose for the brakes from the strut?
    I was going to change the mount that sits at the top of the spring but couldn't get the clip off the strut. I didn't want to force it so i put everything back together and booked the car into a garage to gaet the work done.
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Volvo V50
    Trim : SE Lux
    Engine : 1.6 Drive
    Year : 2011
    iirc i think there is a little bolt that holds it im sure a fellow member will be along to correct me if im wrong.
  1. Are front springs different..?
    By Chunklamb in forum Suspension, Wheels & Brakes
    Last Post: 1st September 2012, 20:47
  2. front springs
    By porthy-t in forum Handling & Braking
    Last Post: 13th May 2009, 18:41
  3. Front springs??
    By mitch1965 in forum Suspension, Wheels & Brakes
    Last Post: 15th July 2008, 13:11
  4. Front springs
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2006, 10:48
