Results 1 to 10 of 15
Thread: Radio problem after install of parrot kit.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default Radio problem after install of parrot kit.
    Hi Guys
    just bought a parrot ck3100 (from bigmac) it works as it should..
    ive got all the wires connected, and also have bought a sot led (the correct)
    when ignition is off no problem everything is off.. (just as it should) (radio works if button pressed)
    when ignition is ON the parrot works... but the radio dosnt.. it just flickers (turns off and on all the time).
    what to do? please help
    (glad i havnt put the dash back together yet.. it will be a pain to get all the wires in there again...)
    Ken
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Are you sure the wires for the sot lead are correct ? i'm sure i read a post on here about some one buying a lead and the wires were in the wrong slots
    Will have a look
    Engine : 2.2 Direct
    bought the sot lead you told me to
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by kenp View Post
    Might be the right SOT LEAD mate but the wires maybe messed up what stereo you got again CDR2005 ?
    Engine : 2.2 Direct
    yes its the CDR2005
    its no good setteing the red/yellow wire straigt (is crossed as it should be..) thats why its strange... maby i should try with out the sot lead.. and go straigt to sterio.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Sounds like there's not enough power to run both maybe running a live from the cig lighter like in the how to
    Surrey
    I fitted one on Saturday on a different marque but I always check the top of the radio as there is normally a pin out there.
    Chester
    I had mine fitted by Halfords as part of the purchase price. It's fitted with the CDC30 Headunit but I seem to remember they took the power from the heater fan control. Don't know if this might help with your problem.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    I didnt even use a SOT lead for my parrot and CDR2005, just cut the ISO block to make it a double and a single, the parrot loom just fits straight into it then with just swapping the yellow and red over.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    or try
  1. Parrot install
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2013, 20:43
  2. My Parrot mki9200 install
    By Niall83 in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2011, 19:11
  3. show me your Parrot install please
    By Big Knox in forum Electrical & ICE (including SatNav)
    Last Post: 26th November 2010, 10:49
  4. Help required after Parrot install.
    By afcajax73 in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2010, 08:45
  5. Parrot 9200 Install Help
    By mickyd98 in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2009, 09:22
vectra c fan inop after parrot kit fitted
can i put sot leads into vauxhall insignia sri 2009
opel signum probleme radio mit parrot
