Results 1 to 10 of 11
Thread: Ncdc 2013....safe mode
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Default Ncdc 2013....safe mode
    Hi, I have the NCDC 2013 Sat nav and after not using the car for a couple of days (with all the snow) the unit flashes up "SAFE MODE" whenever i press the Tuner, Nav or Audio settings. I did start another thread a couple of days ago http://www.vectra-c.com/forum/showthread.php?t=69456
    but the title wasnt entirely correct
    The streering wheel controls have also stopped working but i am guessing this has something to do with the "Safe Mode".
    As said in the other thread, these units dont have a code, so need to know how to get rid of the "Safe Mode"....(Does it need re-pairing with my car? Tech2?) Any help is much appreciated as im out of ideas, Want to avoid stealers if poss!
    Northampton, UK
    Hi there, I think, (a few members mentioned it in one of my threads) that only the full canbus cars are tech2 paired. So the NCDC 2013, which I have too, is not paired, just coded. The code can be bought from VX for something like £18 if you dont have it. But I'm not too sure either way, so dont hold me too it. LOL.
    http://www.vectra-c.com/forum/showthread.php?t=69418
    Full Member Big Sig's Avatar
    Yep, the code is on your car pass! If you don't have one, get down to the stealers for one
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    when i removed my battery to reset the ecu my head unit was saying the same thing, lucky i had the car pass so i entered the code and it was back working fine....diffrent model that yours but im sure it would be the same thing m8
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Yep, as the others have said, you need the radio code from your car pass.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    nope, the NCDC201x doesn't have a code and is a CanBus connected device just like the CDxx-series; so Tech2 is needed !
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    - been there with mine when I first bought the car, I think it had been stood around too long and had to be persuaded by the dealer with Tech2 to talk to the car again. This is an NCDC2013 as well.
    Jan 2008
    Pontefract
    Quote Originally Posted by MysteryElite View Post
    Thanks for the replies, I thought it might need to be tech2'ed as there is no code on the car pass, just a bunch of X's! Any idea how much it would be at the stealers? OR even better.....anyone in the yorkshire area with a tech2?
    Feb 2007
    North Somerset
    Can't say on cost as with mine it was just after I bought that car, so was thrown at the dealer chain to sort it at their expense.
    I wouldn't have thought it would be more than 1/2 labour charge to reset a code unless they hit any interface problems or errors - best to give one a call and see what they say.
    [Ex]Admin Duncan's Avatar
    I'm not saying it's the case here, but there was a known issue with the 2013. The VX Field Remedy basically acknowledged there was an issue with the unit, but had no remedy for it!
  1. Ncdc 2013 radio safe
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2012, 19:27
  2. NCDC 2015 display safe
    By stewartg1 in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2012, 09:34
  3. Ncdc 2013
    Last Post: 22nd August 2012, 12:27
  4. ncdc 2013 radio safe
    By thecarlotz in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2012, 11:58
  5. NCDC 2013 CDC Safe
    By pulseracing in forum Electrical & ICE (including SatNav)
    Last Post: 21st September 2008, 19:23
