Thread: petrol speedo into diesel!
    bonnie scotland
    Default petrol speedo into diesel!
    hi guys i,m wondering if i can fit 3.2 elite speedo to 3.0 cdti they look identical, any ideas.thanks in advance
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Apart from rev counter? I would have thought that the max revs limit of diesel would be considerably lower than the petrol version.
    Changing the instrument panel would probably need Tec 2 for it to work. Other than that can't really see any issues.
    What exactly is it you're wanting to fit - just the speedo part with odometer? The problem you're going to have is that you won't be able to have the new odometer display the mileage that your car has done. The instruments can be Tech 2'd with a new mileage, but only if they're new or haven't done over, from memory, 50 miles.
    Regular Member mattolly86's Avatar
    oxfordshire
    so i think your stuffed pal why would you want to change them anyway?
    I think it may be that the one he's looking at has a chrome ring on it?
    If that's all it is then I'm sure someone, maybe others, have simply transferred that chrome ring over.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Yep i got some petrol SRi clocks cheap and simply stripped em down and took rings off and stripped my dti clocks down and attached rings. Easy mod and looks good to!
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    Quote Originally Posted by steve View Post
    what glue did you use mate as watching a set that im aftrer gutting for the rings
    birmingham
    itried to do the same but failed...bought clocks from 57 reg and tried fitting to 53 reg...totally different in where warning lights are ,then told by vauxhall that would have to be programmed into car as to stop mileage fraud
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    I used superglue 4 little dabs on each ring
    Nov 2007
    Quote Originally Posted by simon1 View Post
    just regualr superglue m8 just be careful take your time... looks good!
  1. petrol in my diesel :(
    By marcel1 in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2016, 16:11
  2. Petrol or diesel
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 14:11
  3. Petrol in Diesel!
    By P-Mutton2.2 in forum Vectra C / Signum Car Chat
    Last Post: 24th October 2009, 06:53
  4. Petrol / Diesel
    By Damian in forum General Chat
    Last Post: 16th June 2008, 21:35
  5. help!!! petrol in to diesel ...
    By lee_eardley in forum Engine & Drivetrain
    Last Post: 30th September 2007, 13:47
