Thread: errorr code p1515
    Regular Member kevinmcm19's Avatar
    LUTON
    Default errorr code p1515
    hi all
    my dad has a problem with the car he started it and it reved up without putting his foot on accelerator he switched off then restarted it was ok then the engine management light came up i have a code reader the error code was p1515 that code according to most sites tallys to (Electronic Throttle System Throttle Position)[/B] does any one know what the problem could be i have cleared it for the moment
    thanks kevin mcmenamin
    Bristol
    Where did you get that code. All vauxhall codes for throttle start 01122 0r 01125. I have just looked on basic code from autodata and its there. Is you car Manual or Auto. I have a Throttle pedal for Vectra c with manual trans .
    LUTON
    hi i got the fault name from the software that came with the code reader (http://www.auteltech.com/gs300.htm
    the car is a manual but we will wait and see it worked ok this morming and the code cleared ok thanks
    kevin
    Blantyre
    DTC P1515
    Circuit Description
    The commanded throttle position (TP), based on accelerator pedal position (APP) and possibly other limiting factors, is compared to the actual throttle position. The powertrain control module (PCM) monitors the commanded and actual throttle position. This DTC sets if the PCM detects the condition.
    May just be the cold playing with the electrics, my window wipers dont work for 15 mins when its cold
    LUTON
    i hope its just the cold as well
    where did u get such a good description of the fault
    from thanks
    kevin
    milton keynes
    hi Kevin , I am in Milton Keynes , if you are unsure about the code I can plug the car into my laptop to find out what faults are active
    Blantyre
    Quote Originally Posted by kevinmcm19 View Post
    from thanks
    kevin
    It just rolls off the tongue
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I wonder if the throttle body may need a clean too??? Is it petrol or diesel?
    LUTON
    hi its petrol that's another good point about the throttle body might need to be cleaned
    thanks Kevin
    Quote Originally Posted by spennny View Post
    You old smoothy, why you not at work again? ..
  1. Dtc p1515
    By swelrose in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2013, 20:43
  2. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  3. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  4. How do i get the code in!!
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2007, 23:02
  5. code for cd 40
    By Eddie Dee in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2007, 01:16
vauxhall astra 1515 fault code
Opel P1515--000
opel vectra 1.9 p1515 code
Fehler p1515 vectra c
vauxhall vectra p 1515
Opel DTC P1515-4
vauxhall code p1515
opel astra p1515
vauxhall vectra Z22se fault p1515
vauxhall vectra z22se fault code p1515
vauxhall vectra fault code p 1515
vauxhall astra 2000 p1515 does not start
storingscode astra p1515
vectra blad p1515
vauxhall astra p1515
p1515 opel vectra
