Results 1 to 10 of 27
Thread: HIDs Installed ish
    Newcastle under Lyme
    Default HIDs Installed ish
    Hi all brought a set of HIDs off JAM Performance on ebay - http://cgi.ebay.co.uk/Xenon-HID-conv...713.m153.l1262. Received great communication and very fast delivery considering the weather.
    Fitted them today (well tonight) into my 08 Vectra facelift.
    Nearside one isnt too hard to fit and inside the battery cover there is a perfect place to screw the balast case without making a hole.
    I couldnt get the clips to fit though which im guessing hold the bulb in. It seems that the lens already has a clip built in.
    The Offside one is a right pain though and requires a lot more fiddling. I'm going to remove the airfilter cover tomorrow and see if it makes it any easier.
    Before fully fitting them I connected them all up in the warmth of the house and once i had disconnected the old bulb I plugged them in and tested them incase there was any problems. I was worried at first but realised it had a positive and negative and switched them round and hey presto. Dont touch them immediately though as damn do they burn.
    Once they are in I found that I was unhappy with the other bulbs and had to make a last minute trip to Halfords to get some LED Parking lights as the original ones glow yellow. Only problem I now have is that the bulb fault indicator has now come on and would appreciate if anyone knows a quick fix that doesnt include removing the bulbs or sticking over the warning sign?
    I also brought a couple of chrome indicator bulbs while I was at it but realised I have to remove the lights to fit them. This modding business is infectious!!!
    I went for a drive and instantly notice a difference in the light output but when I parked in front of a wall I had these peaks in the light level. Is this normal or do I need to adjust them some how as the bulbs only fit one way and clip into place as standard?
    Next mod will either be the induction kit, fitting some chrome surrounds to the fogs but I think this requires me buying new sigma fog lights from what ive read? or fitting some new competition meshing to the front bumper. So many choices.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The best way to do it is to piggyback a pair of bulbs onto the existing side lights and feed the leds from a relay,otherwise the leds can strobe when the car does a bulb check,HTH.
    I noticed the flickering. Can you break down this piggybacking thing? and Relay?
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    get a set of mtec sidelight bulbs thats what you need. vectras dont like leds. the mtecs are lovely
    http://cgi.ebay.co.uk/MTEC-XENON-SUP...1%7C240%3A1318
    Can I legally have blue parking lights?
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    they look blue but when lit they are a bright white
    sorry misleading question. Was wondering if I can actually get a blue tint. as I have 8k Hids
    Does anyone know if the level of the lights looking like this is normal too?
    Aug 2007
    Lisburn, N.Ireland
    only way to know that is to go to a garage and get them tested. i would go with the mtec ones as they will match you hids thats what ill be donin when i fitr mine this weekend. also look good over numberplates
    Plymouth
    Quote Originally Posted by aerodynamic18 View Post
    is it mtech 501's that are needed for the sidelights and number plate lights?
  1. HIDs finally installed !!!!
    By sinless in forum Electrical & ICE (including SatNav)
    Last Post: 16th July 2012, 22:46
  2. gid installed
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 17:53
  3. How to tell if theres a re-map installed???
    By cammy3000 in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2011, 16:27
  4. HIDs Installed!
    By anthonychall in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2010, 22:33
  5. New ICE installed
    By Caterman in forum ICE Gallery
    Last Post: 22nd September 2006, 04:14
