Thread: Vectra 1.9 CDTi advice
    Apr 2006
    Suffolk
    Default Vectra 1.9 CDTi advice
    I have a 56 plate that is driving me round the bend. My local vauxhall dealer keeps giving me the run around and I dont know what to do. I have problems with the tracking keep going out after 6-7 weeks. I have a gentle vibration coming through the clutch pedal as I release it. The exhaust note seems to be getting more throaty, but there is no visable sign of a hole in the exhaust.
    Ive read in various other threads about common problems with the cdti engine, the egr valve, dmf and swirl flaps.
    How do I know If I need these looking at?
    Is there anyone in the Ipswich region who could show me what its all about?
    Regular Member mattolly86's Avatar
    oxfordshire
    how are you as a driver do you hit curbs? other than that make sure its tight underneath. vibration on the clutch pedal usually means your dual mass flywheel and other than that i cant help you sorry
    Leicester
    The 1.9 CDTi is no way as bad as it is made out to be. There are bad ones, but there are bad ones of everything.
    Belfast
    Quote Originally Posted by Maverick View Post
    Yes, it is actually. Talk to anyone who manages a fleet.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Quote Originally Posted by _ZS_ View Post
    this is why i opted for the strong 120ps 8 v.....in my opion much less to do your head in
    sorry that does not help you m8
    if your pedal is vibrating then i would demand them to inspect it as its very costly if it goes wrong
    Regular Member Craig1985's Avatar
    harwich essex
    Quote Originally Posted by GenVectra View Post
    I have used ipswich marshalls and not been happy with their answers, pop along to underwoods in colchester and speak to rob porter (chief tecy) Im sure he'll help, he's a vxl geek
    Nicking Ya Dinner.
    If there's no leaks in the exhaust I'd suggest they check all the hoses around the engine, can be a sod to find though, any smells coming into the car?
    If you want to check the exhaust yourself to certify yourself, get a bunched up rag and hold it tight over the tailpipe, engine should start to struggle if it's airtight, don't hold it long enough to cut the engine out as you are creating back pressure and this can be bad for the engine, so as soon as you hear it hunt release it, might be an idea to get someone else to listen for leaks while you do it. hth.
  1. Help & advice please vectra cdti
    By ONEMINUTESILENCE in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 12:15
  2. Buying Advice for Vectra C facelift SRI Model CDTI 150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2010, 20:56
  3. Need advice/diagnosis re 57 plate Vectra 1.9 CDTi 150
    By TrcikyD in forum Engine & Drivetrain
    Last Post: 21st May 2010, 17:25
  4. Vectra CDTI Advice.
    By PLuKE in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2008, 07:09
  5. Vectra 1.9 CDTi buying advice..
    By Faz in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2007, 01:07
