Results 1 to 10 of 13
Thread: tyre load rating 2.0DTI
    Birmingham
    Default tyre load rating 2.0DTI
    would 88 load rated tyres be ok on the rears of a vectra 2.0dti.
    tyres are 225/40/18. i understand the front is a lot heavier but these will be for the back only.
    [Ex]Admin Duncan's Avatar
    88 sounds too low. I'm sure the minimum you can run is 91.
    Sunny Dartmoor
    My Khumo tyres are rated at 88w and are fine,i do drive a 1.8 though.......
    Yep, but you've obviously replaced the original tyres. What was the load rating on them?
    Quote Originally Posted by shatz View Post
    vectra 2.0dti.
    tyres are 225/40/18
    Checked with ABI and the minimum load rating is 91, with a minimum speed rating of H
    However, if it is a Vectra B, then you can go to minimum load rating of 88
    Birmingham
    surely it varies with either front or rear axle....is this 91 for fronts??
    whats the worst that can happen if i use the 88W's??
    If you use tyres with loading rating 88 and are involved in a total loss claim, then it may be refused
    Although the majority of the engine weight is over the front of the vehicle the weight transfers during normal use, and can be up to 25% above the axle weight
    Birmingham
    other then insurance issues....are there any major safety issues like high probability of blowout...or am i fairly safe in using them?
    And that itself is not a good enough reason to put you off?!
    If you run a tyre with a lower load rating than you need then yes, you do run a good chance of having a blow out. Simple fact is you'd be running a lower load rating tyre than the car is meant to have, therefore putting more load on the tyre than it was designed for - that's what load ratings are for.
    Just ask Mark the Cabby, he had a place fit the wrong load rating tyres to his car, even though it had the correct ones to begin with, and had a blowout on the motorway. He was okay, as was the car, but could have been much worse.
    Why are you so keen to go with 88 rating?
    The tyre would probably be deemed as "unfit for purpose" making the vehicle unroadworthy and could even result in prosecution if stopped at the roadside, or in an extreme case in an injury or death as an indirect result of using such a tyre
    On the other hand, the tyre could be used without any incident at all, but if it does happen then it could land you in a lot of trouble, both legally and financially
    Replace the tyre with one of the correct speed and load rating
    I myself have been unable to use my car today, due to a tyre defect
    A replacement tyre isn't available until Saturday morning
    Even though I could drive with the tyre as is, it's not worth the risk when you know and have seen what can happen with such a tyre, and the consequences of that
  1. Load rating
    By Ziggy in forum Handling & Braking
    Last Post: 23rd January 2013, 15:04
  2. Tyre load rating
    By Threepiers in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2012, 21:18
  3. tyre speed and load rating
    By CLOMP in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2011, 13:21
  4. Tyre Load Rating?
    By Grimy in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 22:17
  5. Tyre load and speed rating
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2009, 23:14
