Results 1 to 10 of 17
Thread: Need to replace all 4 springs - HELP!
    Gloucestershire
    Eek Need to replace all 4 springs - HELP!
    Just had my 03 1.8 Elite serviced at the main dealer as itís LPG.
    They have informed me that I need to have all four suspension springs replaced as the front and rear nearside springs have snapped without me noticing.
    This sounds like a very common problem (64% of poll) and at a cost of £580 I'm not keen to replace them with Vauxhall bits as they clearly don't last.
    As the handling on the Elite was ropey before, can I get away with a better quality set of springs instead (Eibach/Jamex...)? If so, any suggestions would be fantastic please!
    I have done a search on this excellent forum but I have to admit that there is so much info that I am completely lost -Any help would be very much appreciated so I can get back to commuting.
    Regular Member mattolly86's Avatar
    oxfordshire
    your not far from me so if you want new springs fitted you could always buy the springs and come down prob take 2-4 hours depending how we get on
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Defo buy Eibach. Cheap and excellent quality!
    Gloucestershire
    Mattolly86 - thanks for the offer of help, I've managed to find some to do the work but just need to know what to get him to fit:
    Had a look at LMF (approx prices):
    Apex set of springs - £100
    http://www.lmfvauxhall.co.uk/store/p...at=2286&page=1
    Eibach springs - £170
    Jamex Springs - £80
    Spax springs - £115
    http://www.lmfvauxhall.co.uk/store/p...at=2286&page=2
    Or go the whole hog and replace the shocks as well for £270:
    I am not a boy racer, but just thought that if I was replacing the springs a better quality set with improved handling would be nice.
    Thanks for the help so far - kepp the responses coming PLEASE!
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i have pi 45mm front and 40mm rear £110 posted off ebay and it looks and handels great
    Nov 2007
    Ayrshire
    Bilstein B4 shocks £170 and Eibachs for £140. You'll never need to worry about suspension again!
    Sunny Dartmoor
    If i were you and money wasn't a problem then Eibach's all the way,good luck m8......
    Gloucestershire
    Thanks again for all the responses. There seems to be a lot of enthusiasm for the Eibachs -why are they better than the rest?
    Although the B4/Eibach system would be the ultimate solution I think I'm going to havew to calm down as I have to replace teh front pads&discs aswell - current economic climate and all that!
    Just to double check - can I put lowering spring (like the Eibachs) onto the standard elite shocks without any other components?
    Having never lowered a car before is there anything that I should look out for or replace at the same time?
    Thanks again for all your time!!
    Nov 2007
    Ayrshire
    Yeah springs with standard dampers will be fine! Just replace them when they were with bilsteins.
    Eibach springs are very good quality and don't give a harsh bouncy feeling that some other springs do!
    I got mine from 888 engineering sure they were £140
    Quote Originally Posted by Screechxl View Post
    You can, but you won't get the best effect compared to fitting uprated dampers. You can still get a 'double bounce' due to the softer damper.
    To get the best result you want to fit a matched set of springs and dampers. I fitted the Irmscher kit to my Signum Elite and it completely transformed the car.
  1. Going to replace my rear Shocks/Springs
    By Jonsey in forum Handling & Braking
    Last Post: 12th July 2013, 23:50
  2. Replies: 5
    Last Post: 21st July 2010, 16:14
  3. Replies: 39
    Last Post: 26th July 2008, 22:40
