My dash board has an intermittent fault when car is cold (not the engine but the interior). The TC light comes on and the speedo, rev counter etc all turn off then come straight back on again but TC light stays illuminated. Then after it does this a few times usually after 5 mins I also get the battery light on and the clocks all stay off and the indicators won't work. I have to turn the ignition off and on again and all is well again but this problem doesn't happen once the car is warmed up inside.
It would seem to be related to the cabin temperature. Any ideas on what to check and has this same fault happened to any other member?
