Results 1 to 10 of 13
Thread: 3.0cdti dyno graph?
    Kirkintilloch
    Default 3.0cdti dyno graph?
    Hi, does anyone out there have a trace of the power and torque curves (e.g. from a dyno run) for a standard vectra 3.0cdti 6 speed manual (184ps)?
    If you have can you share it with us, please?
    EVERYWHERE
    I'd be interested in that too!
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    I have one in my avatar ... here are the full size versions:
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quite a nice torque rise between max power and max torque engine speeds
    EVERYWHERE
    200lbs-ft at 2000rpm and 200lbs-ft at 4,750rpm.
    Nice graphs,but shouldn't peak torque be a bit higher?
    Tyneside
    Peak torque is 270lb/ft at 2900rpm
    EVERYWHERE
    I thought that it may be closer to the 295 that is claimed for this engine.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It's within 10%, so I'd have thought that's as good as you're going to get at some rolling road place.
    Tyneside
    Especially Regal's
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The 3ltr has quite a large turbo, so hits max power higher in the rev range than many other larger capacity diesel. It helps keep the torque up at the top end though to give better power. The fly wheel and road wheel power would be the same shape in actuallity though with a flattened top (as the road wheel measured values show).
  1. CDTI 120 - 400 nm - check this graph
    By zafira in forum Tuning
    Last Post: 4th June 2011, 09:04
  2. 3.0CDTi Graph
    By Celes in forum Diesel Engine related
    Last Post: 20th May 2009, 00:26
  3. Shazz's RR graph
    By AJA in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 1st October 2007, 12:05
  4. Torque / Power Graph
    By nutron in forum Diesel Engine related
    Last Post: 5th April 2006, 14:33
