Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: fao snowfoam users.
    Regular Member kev bux's Avatar
    Jan 2006
    BOROUGHPETER
    Default fao snowfoam users.
    hi,
    yesterday my super snow foam and my foamlance arrived. !
    as its my first time to use it, how much do you users put in the lance bottle?
    how much snowfoam to how much water or shampoo dou you mix?
    hopefully get the chance to use it at the weekend.
    thanks folks.
    Chester
    About an inch of snowfoam then top up with warm water.
    I don't usually add anything else.
    Jan 2006
    BOROUGHPETER
    cheers mate, thats wot i thought the mix was, but i did read you can mix with shampoo,does this make it any better or not?
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    i put about an inch of snowfoam, which works spot on
    but i have found that you put just a little squirt of shampoo in it is a lot thicker and hangs around alot longer
    i put a squirt of chemical guys maxi suds in, you cant see the colour of car underneath it all, very good!
    all the old boys that live near us, look and laugh and say "i think youve used too much on that son"
    Chester
    Quote Originally Posted by kev bux View Post
    Not for me. Some people add Shampoo so you could try that if just the SF is not giving you the results you want.
    Definitely use warm water though. That does make a difference.
    edit: as above. lol
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Where in the cleaning process is snow foam used? is it wash, sf, polish, wax etc I need to get some of this very soon
    Regular Member ade0303's Avatar
    Quote Originally Posted by Danwells72 View Post
    I usually rinse the car first so the panels are wet, then snow foam, wheels, wash, polish, wax
    Regular Member Lump's Avatar
    coventry
    will be a very detailed thread up on this very soon
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    As Grimo said, about an inch in the bottle and as Steve said, top up with warm water.
    I also add a little squirt of shampoo to the mix as it thickens it up.
    Before applying, pressure wash off as much of the grime as you can, but not too close to the bodywork or you'll remove your wax/polish. Aim the jet at about a 45 degree angle so that your not blasting the grit into the paint.
    As mine is black, i do the above and apply the snow foam, leaving it to dwell for about 10-15 mins. Pressure wash it off and do the snow foam again, leaving for another 10-15 mins before washing off. Then wash it using the 2 bucket method and a lambs wool mitt. If you've recently waxed it then a quick spray of quick detailer and job done.
    HTH.
    Snowman, you got your ears on?
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Quote Originally Posted by Stevel View Post
    and I asked simular questions when I got mine
  1. I'm off to snowfoam the VXR......
    By peelmeister in forum Detailing and Car Care Discussion
    Last Post: 20th February 2012, 08:58
  2. best place to buy snowfoam lance and snowfoam
    By paul_sri150 in forum Detailing and Car Care Discussion
    Last Post: 31st January 2011, 23:04
  3. Snowfoam
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2010, 21:39
  4. Tried to have my snowfoam away
    By shan in forum General Chat
    Last Post: 17th April 2008, 23:08
