Thread: Throttle control
    Oxford
    Default Throttle control
    OK so its only a 1.8 VVT Design, but I like it, apart from the way the throttle works. She/He/It (PC) wont be hurried through the gears.
    When ever I lift to change gear and depress the accelerator the revs climb 500rpm before falling away and if I change gear too quickly the clutch snatches and car lurches. Is it really my timing.... I drive a number of different cars and the gearchanges are smooth and as quick as I like in those.
    I know there is a lag in the electronic throttle system but it should react like this, is there a different mapping for the ECU that can be applied. I have checked with the garage and had the car serviced, but no help.
    Anyone got any ideas.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It's not really 'lag' in the electronics, but an intentional feature to make driving smoother, as the throttle effectively is damped to 'smooth' out rapid throttle changes. Sportier model calibrations may have reduced dampening to improve responsiveness to throttle position, BUT rapid lift off throttle snap can lead to over steer conditions, not good in most cases.
    In other words, it's not really a fault - so the VX monkey won't know / have the ability or equipment to change it, as they can't modify calibrations.
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Mines the same m8, I think its a case of its how they are.
    Bring back carbs I say
    Oxford
    Ste;815407
    OK so not really lag and I understand the theory on throttle dampening, Ford uses it with great effect in the Focus, BUT when lifting off the throttle to change gear the revs shouldnt rise 500rpm hold for split second before falling away. I think Ford have figured out that if the clutch is depressed then the "smoothing" effect is cancelled allowing the revs to drop away ready for pick up when the clutch is re-engaged. I cant help feeling there is a sensor somewhere thats not working properly, but then with the Canbus that would show on the diagnostics.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I don't know if the clutch switch has a fed into the ECM, but you can try it and see if it works by pressing acc, then slightly pressing clutch - but not enough to cause slip. The engine should derate to zero throttle - well mine does anyway.
    As the Vec was designed as a motorway cruiser, I would have thought that the throttle dampening would be fairly aggressive to make it a smoother ride.
    Mine does it too, how long have you had the car? It could just be a timing issue of lifting off and going on clutch. Maybe you'll get used to it's little furbells.
  1. will 07 throttle control fit 05?
    By geordieric in forum Engine & Drivetrain
    Last Post: 5th June 2011, 16:32
  2. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  3. Throttle control
    By Zeppelin in forum Engine & Drivetrain
    Last Post: 3rd February 2010, 17:44
  4. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
  5. dodgy throttle control valve
    By micksig in forum Engine & Drivetrain
    Last Post: 23rd March 2008, 16:43
