Results 1 to 10 of 16
Thread: Return to car and the windows are down??!! : WTF??!!
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    Default Return to car and the windows are down??!! : WTF??!!
    Hi,
    This has happened a couple of times, mostly last year.
    But it did it again last week and yesterday.
    Go to work, park car.
    Go out to car to go home 10 hours later and both front electric windows have opened down about 4 inches, both exactly the same on each side.
    What the hell causes that?
    Falkirk, Scotland
    ******, suppose I should really have put this in the Technical section.
    Regular Member Vectralicker's Avatar
    Fife - unfortunately
    Quote Originally Posted by RSV_Ecosse View Post
    Hi,
    dunno another lad on ere is having same issue.
    i was told that you can rectify it by resetting the windows.
    sit in car ignition on but not running the engine.
    start with windows up.
    hold both buttons down until they get to very bottom.
    then keep holding for bout 20 seconds
    then put em back up at same time until they close and hold for 20 secs
    not sure if it works as never had to do it, but seems to resolve most lecy window issues on vecs. helped when my one touch stopped working!
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Ive had it happen once.
    I think as mentioned above its something to do with settings. i got back in mine and held the button down for a good while and it hasnt happened again very werid feature
    Regular Member scottyd's Avatar
    paisley
    you must be pressing the keyfob for too long when opening the doors that causes the windows to go down
    Falkirk, Scotland
    Cheers, I'll try that reset thingy.
    So - Is it a fault or a feature then?.
    If it is a feature, what on earth is the point of it?
    Quote Originally Posted by scottyd View Post
    No m8, I lock the car up using the remote and it's all normal. When I go back to the car later, before I even press any buttons on the remote, the windows are already down.
    Mileage : 000
    Now in the electrical/technical section.
    Regular Member falco's Avatar
    Jun 2007
    Cockermouth
    Thankfully haven't had a problem with that yet.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Just as an aside you only need 2 secs fully down or up and not necessarily at the same time. You have to do this if you disconnect the battery and the autodown and autoup functions have to be reset so it needs the references. It seems that it is more to do with the keyfob as holding the shut button also does this.
    Regular Member gibbon7000's Avatar
    lincs
    Quote Originally Posted by Vectralicker View Post
    Will have to give that a go, All 4 windows were all down 2nd day I had my siggy. Does it work for the rears aswell???
  1. Return of the Vec
    By R-man in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2012, 10:04
  2. Possible return to VX!
    By stevie16v in forum Introduce yourself.
    Last Post: 19th February 2010, 02:08
  3. Windows Wipers and Windows Washers
    By kevrod79 in forum Electrical & ICE (including SatNav)
    Last Post: 19th February 2009, 09:58
  4. Return
    By WHOOSH05 in forum General Chat
    Last Post: 16th December 2008, 20:35
  5. On my return
    By alex_c in forum Introduce yourself.
    Last Post: 18th February 2008, 21:04
car windows going down when engine off on a vauxhall vectra
