Thread: Heater / blower problem
    Abbots Langley
    Default Heater / blower problem
    Hi there,
    I'm new to this forum having just bought my first Vectra. 55 plate, got it cheap at an auction, but having to fix a few issues with it....
    I had the local garage replace the blower motor as that was packed up completely, but I now have the problem where I just don't seem to be getting enough air through into the car.
    I've checked all the common faults out on here (thank you guys! ) and the blower is working on all four settings, the pollen filter has been replaced and the drain hole checked. I've also checked the blower position settings, and as I move the control the air does come out of the right places, so it looks like the servos are all working ok. The recirc button works fine (now I replaced the fuse that was missing! ) and increases the airflow slightly.
    Are there any suggestions as to whether I have a blockage and where it might be, or is it more likely that the new blower just isn't up to snuff, or am I expecting too much compared with my old VW Passat? lol
    Would appreciate any help...
    Jonathan
    LOWESTOFT
    Default Blower problem
    I am a New member but i have the same problem as the member above.It is interesting to see that there does not appear to be any solution to it in the last year. If any one has a solution i would be very very grateful.
    ndwright
    Regular Member suj786's Avatar
    glasgow
    try it again with the pollen filter out.
    I was told my pollen filter had been changed. barely any air getting through vents. took filter out and hey presto, works great. changed the pollen filter and all working fine now.
    Northampton
    i have had the same problem...i saw another thread to change the heather motor resistor.. this did not help! i get air slightly through 2 and 3 but only works propa on 4. tried the pollen filter but that didnt change. dont know if i have to replace the motor?
    Regular Member Silentknight's Avatar
    Swindon
    Sounds like you may have to change the motor, probably partially ceased.
  1. Heater Blower Strange Problem - Help!
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2014, 22:38
  2. '02 GSI, heater/blower problem
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2011, 12:54
  3. Strange Heater Blower problem
    By dickybow in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2011, 22:19
  4. heater blower problem
    By manunut1969 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2010, 02:17
  5. Blower / Heater Fan Problem
    By zealot210 in forum Bodywork & Interior
    Last Post: 11th January 2010, 17:38
