Results 1 to 10 of 16
Thread: auto-diming wing mirror not working
    Regular Member murf2484's Avatar
    Apr 2006
    normanton west yorkshire
    Default auto-diming wing mirror not working
    Ive been meaning to post this up for ages for some advice, i have a 2006 56 plate Design and the wing mirror doesnt dim a night but the rear viw mirror works fine, the glass is ok . Any ideas or advice will be most welcome as id like to get the mirror working
    Sunny Dartmoor
    Might be a wire come off in the mirror itself or a fuse gone???
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Just because you have the internal mirror doesn't necessarily mean the drivers door mirror is a dimming one. Has it ever worked?
    Apr 2006
    Quote Originally Posted by paulhb View Post
    the actual mirror/glass is different than the one i had in my Ls it has a wider border around the glass, as its a design model it should work with the rear view mirror, i only got the car back in augst 08
    Apr 2006
    Quote Originally Posted by glenboy View Post
    Thanks ill check the fuses but with the heated section working ok will the dimmer be on a different fuse. Is it easy to take the mirror off to check to see if a connection has come off the back of the glass
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Mine is a design with autodimming rearview mirror but not the drivers door mirror no wiring or door module for it.
    [Ex]Admin Duncan's Avatar
    Did it come with the dimming mirror as standard or have you retro-fitted the dimming glass? i.e. has it ever worked?
    The dimming glass is easy to identify as it has a black border around the edge.
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If you have the wide border it should be the one pity I don't have one to swap and check your wiring
    Apr 2006
    Yes Duncan it has abroad edge around the mirror
    Apr 2006
    Thanks Paul its wide border ill check the wiring
  1. Wing mirrors working together?
    By s0501291 in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2015, 17:29
  2. auto dim mirror, not working
    By male 2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 24th October 2012, 18:45
  3. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  4. Auto dimming wing mirror info request!!!!!
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2008, 19:04
  5. Auto dimming Wing Mirror or Mirrors?
    By Craig Rogers in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2008, 12:30
vauxhall vectra c autodimming rear view mirror wires site:www.vectra-c.com
