Thread: temp gauge
    Regular Member ptrehearn152's Avatar
    norfolk
    Default temp gauge
    my tempt gauge appears to have stopped working, only had a brief look due to working, does anyone know where i would find the temp sender unit? does it have one or is it one of those ecu issues? thanks for your help. sorry it's a 2.2 dti elegance 2004 model.
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    are you sure its stopped working , try letting it idle for a good 20 mins , they take forever in this weather
    norfolk
    pretty sure it takes a good 20 mins to drive home from work and for two days it hasn't budged from below zero but the heater is warm, i did notice last week it was on zero but when i sswitched off for a few mins and started again it went up to 85, but hasn't done any thing since, thought if there was a sender might be able to put wire straight to earth to confirm gauge is ok
    Apr 2006
    Wigan
    im driving 11 ,miles to work and its not budging but it does work , i got stuck in a jam last week and it did eventually move
    milton keynes
    could also be a faulty thermostat
    norfolk
    recon i'l give it a good going over at the weekend, will let you know what happens.
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    I had the same problem, I changed my thermostat on sunday, works perfectly now.
    Regular Member badback's Avatar
    Runcorn
    Mines the same only moves now and again.
    Regular Member Warrenmole's Avatar
    West Yorkshire
    yeah, i've noticed mine being a little lazy, stays on 0 most of the time will move alittle bit upwards after 20mins in car but then goes back to 0.?? I take it this is not normal
  1. temp gauge on 1.8
    By MID LIFE CRISIS in forum Engine & Drivetrain
    Last Post: 14th January 2010, 22:10
  2. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  3. Outside temp gauge
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 20:47
  4. temp gauge
    By cow monkey in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2007, 16:22
