Results 1 to 10 of 19
Thread: What are pitted discs?
    Birmingham
    Default What are pitted discs?
    hi, got my car car back from MOT and in the advisory section it says front discs slightly pitted. What does this mean??
    do i have to get them replaced or is it ok as i am totally broke and will be for a while...dont really want to spend money on the brakes if i can avoid.
    Regular Member Robbie69's Avatar
    pitting is a type of corrosion. HTH
    [Ex]Admin Duncan's Avatar
    Lots of little corrosion/rust pits (imagine like digging a shallow hole). EDITL or look at the link from Robbie!
    As it's only an advisory then they obviously weren't bad enough to fail - just keep an eye on them for getting worse.
    Birmingham
    is it an idea to get the old angle grinder out and give them a slight polishing/grinding just before the next time i go for MOT. Its been 8 months or so since my last MOT...and i dont want to get failed next time.
    you could but i'd just get some new discs!
    Birmingham
    i understand there is a HOW 2 section on here that may tell me how to change myself....but in your opinion...how difficult or easy is it to change just front discs and pads??
    I've not done it but I wouldn't think it was difficult at all mate. If I lived nearer I'd give you a hand.
    Mileage : 000
    Quote Originally Posted by shatz View Post
    DO NOT EVER DO THIS TO YOUR DISKS. IF YOU GRIND THEM UNEVENLY YOU WILL CAUSE THEM TO SNATCH OR DISTORT. If they are pitted they will need to be replaced. for your own safty.
    Birmingham
    anyone else got any experiance?
  1. pitted crome lip
    By happypostie in forum Detailing and Car Care Discussion
    Last Post: 11th April 2009, 22:31
  2. new discs
    By bigron1988 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2009, 02:22
  3. Replies: 1
    Last Post: 21st October 2008, 15:11
  4. Can you fit 314mm discs to replace discs on back wheels of a GSi 3.2???
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 21:10
  5. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
vectra c front pitted discs
