Thread: Rear parking sensors
    cambridgeshire
    Default Rear parking sensors
    HI chaps quick question looks like my rear parking sensors have packed up, I put the car into reverse and the start beeping like a demented rave, however they certainly don't measure distance, I tried it but fortunately it was only a hedge I backed into (slowly of course).
    Any thoughts or is it a trip to the dealers to get them to fix them?
    Ian B.
    May 2007
    West Yorkshire
    Are they factory fit or aftermarket? if aftermarket then a replacement set to isolate the fault, i.e sensors or unit, it sounds like just one duff sensor. If factory fir then locate the control and unplug one at a time to see if you can isolate the faulty sensor.
    Surrey
    Are they clean?
    Sussex
    Are they frozen up?
    Blantyre
    Are they there , or was ther Mrs saying ..beep......beep.........beeeeeeeeeeeeeep
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It is snow or ice in the sensors they all do they need cleaning out if it annoys and you are not reversing just switch them off.
    Jul 2009
    SE
    I know this is an old post but still relevant! Mine has started doing this - was going to get the garage to check it out when the next service due. How easy it is to check the sensors to make sure they are clean (nnot knowing the first thing about them!!). I take it is not as simple as wiping over the plastic covers?!
  1. Rear parking sensors (oem)
    By AKeeNShoT in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2010, 09:32
  2. Rear parking sensors
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2010, 16:56
  3. Rear Parking Sensors
    Last Post: 22nd April 2009, 23:44
  4. Rear parking sensors
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 22:44
  5. Rear Parking Sensors.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 12:11
