Thread: Climate Control Fan Issue
    May 2006
    Mansfield
    Default Climate Control Fan Issue
    Good People,
    Interesting one this morning - set off as normal (after having scraped snow ,ice of windscreen & windows)
    Put climate control on front window demist and drove as normal, noticed that fan had not slowed down and would not respond to 'manual' the numbers in the display went down but fan kept going.
    Now pulling up at work, turned the ignition off - fan keeps on running - had to remove CC Fuse to stop it - any ideas ?
    SJ
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Try it again and if still doing it sounds like a sticking relay (for full fan speed) - on my A/C only car, going to fan speed 4 activates an additional relay in the glovebox area (from memory)
    May 2006
    Mansfield
    Quote Originally Posted by Ste View Post
    Thanks Ste,
    Unfortunately there are no relays - as this is a full climate control spec all done by electronics. I've looked on TIS and suspect its probably the Motor regulator module becoming waterlogged with the melting snow (did have some water in the footwell).
    Anyway I will dismantle and see if I can dry it out / repair.
    SJ
    Wondering lonely as a cloud
    21 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    It might be the resitor pack in the passenger foot well and check the scuttles under the pollen filtewr to make sure they are clear and they tend to block and water comes into the car and soaks the resistor pack.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by sjanisz View Post
    Thanks Ste,
    SJ
    No worries, I saw it was CC, which is why I mentioned mine was A/C - thought maybe there could be a similar arrangement. Clearly not in this case.
    Good luck with fixing it, and if you do, post up your answer to the problem.
    May 2006
    Mansfield
    Thanks People,
    Planning to investigate/dismantle/repair tomorrow, will let you know the gory details
    SJ
  1. Another Climate Control Issue. Help please....
    By Murdoch Troon in forum Troubleshooting
    Last Post: 26th July 2012, 11:14
  2. Climate control temp display issue
    By Greebo in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2012, 14:11
  3. 05 Elite Climate control issue
    By graham22vti in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2011, 11:41
  4. Climate Control
    By liphook in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 04:10
