Thread: ABS light on & Speedo jumping about on Astra
    May 2008
    Alloa (scotland)
    Default ABS light on & Speedo jumping about on Astra
    My Mate has asked me to find out if anyone knows what the problem could be with his Astra . The ABS light is on and the speedo needle jumps about . I thought maybe the speedo sensor might be on the same side as the faulty abs sensor , Maybe its been hit with something . could anyone tell me if this could be the case .
    Think its a new shape astra
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Your speedo will take a reading from the abs, faulty abs will mean faulty spped reading. I suspect you have a faulty abs sensor somewhere.
    May 2008
    Alloa (scotland)
    Cheers Mate . gonna have to go and plug the fault finder into it now , once i find my snow shoes .sled and huskies to get there
    Regular Member solorider's Avatar
    swindon
    it will be the n/s/f abs sensor/hub,could be abad connection but probably the actual hub asm is faulty
  1. Flat Battery = Jumping = Warning light = Safeguard
    By HITFACTORY1403 in forum Troubleshooting
    Last Post: 27th June 2012, 18:38
  2. Astra spanner light
    By fenderguitar in forum General Chat
    Last Post: 1st June 2008, 23:04
  3. Warning Light on 1.9CDTI Astra
    By markm in forum Engine & Drivetrain
    Last Post: 18th July 2007, 15:16
https:www.vectra-c.comforumshowthread.php69291-ABS-light-on-amp-Speedo-jumping-about-on-Astra
