Thread: vectra 2.0tdi
    ireland
    Default vectra 2.0tdi
    I need an engine for my 2003 vectra 2.0dti, are the engines the same as the older 98/99 models or does it have to be out of the same year of car ?
    Full Member
    Bristol
    Default engine
    THey are different you will need on from the same year or same range with exact engine ID. hp power ratings are different that means pumps are as well and you need to match to ecu.
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Just done this pal..
    Mine came from another 03 2.0 DTI.
    Swap the HP Fuel pump over from yours to the new engine (time chain issue) thats it mate.
    Put the new one in.
    Done! No tech needed!
    Not that much of a hard job tbh. I had some help with timing on the pump thats it.
    Good luck
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    As andy above, they 'new' engine just has to be the same engine type and take the 'old' injection pump to it. No issues, timing shouldn't be a huge problem and it's better / easier to refit the pump before fitting the engine in the car.
    In fact, if the fuel pump on yours is suspect, I would have thought that you only have to transplant the ECU on the back of it and not the whole pump - that assumes you can separate the 2.
    Word of warning, fuel pumps operate at very high pressures - enough to inject diesel into your skin, so be careful when releasing any pressurised fuel, and be sure it is all extremely clean, as dirt will cause issues.
    ireland
    thanks everyone for the help
    much appreciated
  1. thoughts on Audi A6 2.0TDI S-Line
    By chewy71 in forum General Motoring Chat
    Last Post: 13th August 2012, 09:27
  2. hello to all, just bought my first vectra c 2.0tdi.
    By hgvdriverpeter in forum Introduce yourself.
    Last Post: 26th July 2012, 16:43
  3. vectra c 2.0tdi on 52 plate
    By hgvdriverpeter in forum Engine & Drivetrain
    Last Post: 23rd July 2012, 21:58
  4. Does anybody know if this will fit a 2.0TDI
    By danny1992 in forum Diesel Engine related
    Last Post: 9th November 2010, 17:05
  5. 2.0TDi Queries
    By moonym20 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2009, 14:43
