Results 1 to 10 of 13
Thread: Help with fog lights
    Regular Member Signum Mad's Avatar
    Lisburn
    Default Help with fog lights
    I have just fitting a set of HIDs, yes there gd brighter. Bt is thereany way i can get my fog lights to b a bit bluer just to match the HIDs. or do i have to buy an other set off HID for fogs??
    Thanks boys
    Full Member Penfold101's Avatar
    Second answer mate. You can get the blue bulbs that put out the white light, but seeing as the fogs produce so little light to begin with, it's really not worth spending the money on an HID kit for them...
    Plus I'm not sure where you'd put the ballsts and cancellers...
    5 Post(s)
    For the two or three occasions during the year the fogs *may* well be used, is it really worth it? Unless of course you drive around with them on when its not actually foggy?
    playing with spanners
    get them
    hid fogs rule !!!
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Regular Member G.T.S's Avatar
    Helsinki
    How did you make them work in the fog's those hids?? i bught H3 Hid set and started to fit them but there was i bulb with a wire in it but not the other wire?? so can i hawe some help? BIGRON1988 or bobby-tupper?? photos perhaps?
    i just retro fitted my fog lights so just had a power and earth that conected straight up to it
    Helsinki
    Quote Originally Posted by bigron1988 View Post
    Any pictures of that fitting?? where did you get the povera and the ground?? i'm not a expert with elektriks
    no pictures sorry mate , just power from the batery to a switch then to the fog light , and the earth to the body of the car
    Regular Member NI-2.2SRI's Avatar
    Northern Ireland
    --to bigron1988--
    is that HIDs in ur full beam and dipped?? do they make much difference on full beam?? sori if this question has bn asked b4
    cheers
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
