Thread: Diesel pump connectors???
    Regular Member John3v36's Avatar
    NI
    Default Diesel pump connectors???
    would anyone be able to enlighten me on the whereabouts of the diesel pump and its connectors on the 2.0dti?? my haynes manual isnt too clear!! any photos too would be appreciated!! thanks
    EVERYWHERE
    Better to post that in the 'Engine & Drivetrain' section for best results.
    No moved for you.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If you remove the top cover, you can just follow the injector lines down - that is the pump
    NI
    thanks D. injector lines down???eh??? still not too clear/sure!!
    its to try and fit a tuning box!!lol who has one on 2.0dti, and how u put it on???they say its only a 20min job too!!!lol
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Without sounding too harsh, if you can't locate the fuel injection pump, then you maybe should entrust the fitting of the tuning box to someone else. If you follow the metal pipes that come from each injector, they all converge on the pump - as you'd expect.
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Your a brave man!
    Its not suposed to be a good pump on this engine.
    Front left of the engine ^ as they say ^ follow pipes down.
    Its not that easy to get the connectors off. And there are 2 Which one? The one nearest to the Aux Belt is the hardest to remove.
    Good luck mate
  1. Diesel pump
    By ads3 in forum Engine & Drivetrain
    Last Post: 9th June 2011, 18:57
  2. Diesel pump???
    By pasty steve in forum Engine & Drivetrain
    Last Post: 15th September 2010, 15:34
  3. Diesel Pump?
    By jrpatten in forum Engine & Drivetrain
    Last Post: 14th February 2009, 21:47
  4. Need me a diesel pump!!!
    By cov in forum Engine & Drivetrain
    Last Post: 20th January 2009, 18:42
  5. diesel pump!
    By littlesxi in forum Diesel Engine related
    Last Post: 29th January 2008, 01:15
