Thread: How to change fuel filter?
    Regular Member danlat1415's Avatar
    Lancashire
    Default How to change fuel filter?
    Hi guys,
    I've bought a few parts from http://www.vauxhallworldparts.com/ which by the way, is CHEAP compared to dealers.. (Oil filters etc - 99p)
    One of the parts I got was a new fuel filter. I've had the Vectra for 3 years now, and it's not had the fuel filter chnaged since I've had it.
    Does anyone know how to change the fuel filter on a 1.8 Petrol?
    I've done a bit of research, but most of the websites I find that help are for USA vehicle, and say you've got to remove the fuse for the fuel pressure system before you do it, but the UK websites I go on don't mention this.
    I also search this forum for some help, and could find a couple of threads relating to the Diesel engine which suggests you've got to fill up the fuel filter with fuel before you put it on the car, otherwise the air gap will cause problems when the fuel starts pumping again...
    I know roughly how to change it, but want to make sure before I do it, because this seems like a part - if you mess up, could cost a lot to fix...
    Dan
    Mileage : 000
    I never remove any fuse,e when I change the filter. Did you get any new clips with the filter, as there is a chance you will brake one or both. The filter can be tight in the carrier and the clips can be a bit awkward to get off, gut not too difficult a job. You will lose some petrol as it drains out from the filter.
    Belfast
    99p oil filters? Good luck with those.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by ed taylor View Post
    Definitely make sure you get the new clips with it. If you get up close to it with a lamp you'll see how the clips release. You'll need a set of 45/90 degree circlip type pliers to make the job easier.
    As Ed said, I've also never taken out a fuse, can't see why you'd need to. The fuel pump only starts up and pressurises the system when you turn on the ignition.
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Last time I took my car to the stealers for its service stamp, they chargd me for a new clip when they changed the fuel filter. I knew damn well that they came with clips, I also knew that 50% of the time one will brake..........
    I didn't think they came with the clips? I'm sure mine didn't when I bought it i.e. weren't in the box and I bought them separately.
    Oct 2007
    south wales
    Only seen them once, and the guy said they came with clips? maybe they dont? maybe he just broke the old ones?
    Mileage : 000
    Mine too. I have always bought the clips separately.
  1. 2.2 dti fuel filter change
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2012, 08:57
  2. Fuel filter change?
    By parky1 in forum Engine & Drivetrain
    Last Post: 13th August 2011, 22:24
  3. fuel filter change vec c 2.0t
    By johnturbo in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 19:36
  4. Fuel filter change
    By juggernaut in forum Engine & Drivetrain
    Last Post: 5th March 2009, 16:18
  5. 1.9 Fuel filter change
    By Keith Jones in forum Engine & Drivetrain
    Last Post: 11th October 2008, 21:11
