Results 1 to 10 of 23
Thread: Cruise Control switching off by itself
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Cruise Control switching off by itself
    I use cruise control every day on my 25mile m-way journey to work but over the past month it has been not engaging or switching off. It now puts up a real fight to come on.
    How do you clean the stalk??
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    to remove the stalk get some mig wire and looking under the stalk is a groove,slide the mig wire down the stalk the stalk should just pop out,you simply wipe the visible contacts with a piece of rag or cloth.,this should be enough as where the stalk goes in is a bit awkward,you may find some grease when you remove the stalk,i did when i removes mine
    Jun 2006
    North West
    Thanks for the reply.
    Where abouts do you need to insert the wire?
    I have had a look and can't see any grooves or holes anywhere?
    Do you have to take the steering column shroud off??
    Is it hiding under the rubber boot at the bottom on the stalk?
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    you do not need to remove the shrouds,if you pull back the boot and look under the lever
    Jun 2006
    North West
    Sorry to keep going on about this.
    Underneath the rubber boot I can see two places that could be used to prise bits apart.
    The first picture shows the top part of the indicator, I can get some wire/small screwdriver in the the red circled bit and it looks as the the blue section will prise out.
    The second picture shows the bottom part of the stalk. Again I can get something into the red circled bit and the blue section lokks as though it come away.
    I have had a little go at both of these points but nothing loosens easily?
    Which bit should I be prising apart?
    swindon
    Vehicle : Insignia
    Year : 2010
    Mileage : 92274
    this is a view of the lever underneath as if you were looking straight up,this is the groove
    Jun 2006
    North West
    Thanks, So is the blue line where I am trying to prise apart?
    Jun 2006
    North West
    Quote Originally Posted by Marky View Post
    I am missing the obvious aren't I!!
    Its the green arrow Isn't it?
    Jun 2006
    North West
    Yes, I was missing the obvious.
    I poked a large straightened paper clip down the groove (as shown by the green arrow) and the stalk just pops out. Easy when you know how!
    I have given it a quick wipe as there was a bit of blackening and grease on the connector.
    Haven't had chance to see if its has fixed the intermittant cruise control yet. I'll go out later.
    Thanks Solorider
    Regular Member Hynzy's Avatar
    Liverpool
    let us know when you find out mate, mine does the same thing.
  1. Cruise Control Switching Off??
    By JDX-SRI in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 01:05
  2. cruise control switching off ?
    By formby in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2009, 20:57
  3. cruise control
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2009, 18:34
  4. cruise control
    By steeb82 in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 23:47
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
