Results 1 to 10 of 19
Thread: I am puzzled
    Regular Member Messenger's Avatar
    Hampshire
    Default I am puzzled
    What was the thinking behind Vauxhall having their dash lit all the time?
    I realise its normal and I have read all the threads using search etc but out of curiosity why is it like it?
    It just seems strange and I can't think of the reason
    Mileage : 000
    How do you mean Dash lit all the time. Mine is only lit when the side/head lights are switched on.
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    You meen the speedo and rev counter part of the dash?
    If so, mine doesn't. It lights up when you unlock the car, but when you start it up the lights go out
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    Quote Originally Posted by Waterboy View Post
    Feb 2007
    North west
    mine is lit whenever you are driving, it makes it easier to forget to put your lights on if anything.
    Here, there and every where!
    Facelift model have the dash lights on as soon as you turn on the ignition, several car makers are doing this now
    As Rob says, it is very easy to forget to switch lights on because of it
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    i have forgotton to switch nime on once because of this. i also wonder why when you switch on you dipped beams another little indicator doesnt come on because it just uses the same symbol for the dipped beam as well as side lights !
    Quote Originally Posted by aerodynamic18 View Post
    I think this is called progress, probably an EU directive or something..
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    mine does this, the dash lights on all the time
    i pressume (but im probably not correct) if you go under a bridge or something you can still see your dials
    if you have cd70 the screen turns a differnt colour when lights are on
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Caterman View Post
    Facelift model have the dash lights on as soon as you turn on the ignition, ...
    Was a new 'feature' Vx brought in. I can't recall if it was specifically facelift or on full CanBus that it appeared? - anyway, it was that sort of time.
    I can see their reasons for doing it - means you can always see your instruments easily - but as said it's going to make it easier to forget to put your lights on as it gets towards dusk.
    I drive with my lights on all the time, and as mine doesn't have that feature I can see straight away if my lights aren't on. I think if I had a facelift car I'd want that feature turned off as I'd probably forget on occassions to turn my lights on during the day.
  1. Puzzled on car now
    By Alank in forum Engine & Drivetrain
    Last Post: 12th June 2011, 11:49
  2. Puzzled
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2011, 09:13
  3. well puzzled ......
    By westwoodz in forum Suspension, Wheels & Brakes
    Last Post: 14th May 2009, 18:21
  4. new member puzzled
    By davidjameswest in forum Introduce yourself.
    Last Post: 16th March 2009, 15:22
dipped beam symbol vectra c www.vectra-c.com
