Thread: How 2 solve intermittent hatch open warning
    Newcastle upon Tyne
    Default How 2 solve intermittent hatch open warning
    Intermittent hatch open warning with unwanted rear numberplate lights on and other hatch locking malfunctions were traced to a problem with the hatch lock shown in picture. Full details on how to access this are in the Haynes Manual. The unlock actuator gearwheel is pushed to the left on the helix rotated by the lock motor but then sometimes fails to return fully to the right under spring return due to friction. The gearwheel is shown stuck in mid-position. The microswitch slider (top visible on the left) is operated when hatch is closed but is blocked from moving fully home and a hatch "open" signal is given even though the lock clasp is fully engaged. The remedy is a very small application of WD40 to the actuator helix which results in very rapid actuator return.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    good tip - the other day I had to shut the boot three times before it registered. Must add this to my to do list. Thanks
    Newcastle upon Tyne
    I've been told that WD 40 tends to dry out over the long term so perhaps a very light grease would be better.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Or 3 in 1 spray with essence of PTFE http://www.screwfix.com/prods/84222/...ubricant-400ml
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    good tip
    Good post & love the clear picture.
    Hampshire
    good job
    I need do this to my signum
    Newcastle upon Tyne
    Default Update
    Over 3 years on from the date of repair, I am pleased to report that the lock indication is 100% correct and hence the WD 40 is still effective.
  1. Hatch Won't Open - intermittant fault
    By wafoo in forum Bodywork & Interior
    Last Post: 2nd February 2013, 20:33
  2. Strange intermittent left fog lamp warning
    By rheumatoid in forum Electrical & ICE (including SatNav)
    Last Post: 19th May 2012, 12:02
  3. intermittent check rear bulb warning
    By parttimer1 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 19:33
  4. Intermittent warning lights
    By juggernaut in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2011, 02:03
  5. Intermittent battery and steering warning lamp
    By Rapier in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2009, 18:15
