Thread: High pitched noise coming from front right wheel?
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Default High pitched noise coming from front right wheel?
    Afternoon all! Just thought id throw this one in and see if any1 has an idea whats going on. Basicall from 50mph+ accelerating in a straight line there is very high pitched noise coming from the front right brake, this stops when i press the brake pedal but comes back when i take my foot off, its also making the noise when i go around corners, any suggestions
    Regular Member fredfox_uk's Avatar
    Northants
    Wheel bearing ? Is there lots of play on that wheel ?
    Jan 2008
    South Wales
    Quote Originally Posted by fredfox_uk View Post
    Iv recently had a service and asked my m8 to check all wheel bearings for play but they r fine, it sounds like there is a stone or something trapped between the pads and disks but iv taken the wheel off and had a poke around but cant find anything. I was thinking mayb the disk or pads r loose causing friction somewhere and the high pitched noise, odd it only happens going around corners and in a straight line over 50mph?!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by VXR CDTi View Post
    Exactly what I had on my GSi @ 67k miles. Turned out to be f/n/s bearing . When going round corners, you're putting load on the the bearing, hence the noise. In a straight line, the defunct bearing starts to float and usually shows itself as a droning noise.
    With the modern design of needle roller bearings, it's almost impossible to detect play in them. Not like the good old days when we had hubs running in ball bearings when you could detect play.
    Northants
    Quote Originally Posted by gtr1000 View Post
    Showing my age a little I guess !
    Jan 2008
    South Wales
    Theres no droaning noise tho its just a high pitched screach but i know the noise u mean coz iv had 2 change bearings on lots of me older cars! Ill get it checked on my next day off just to be on the safe side, cheers GTR1000
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    i think something might of got trapped between the dust guard and your brake disc ...worth cking that out ........i use to work on a farm site and was often getting twigs and stones caught in there
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by soulman View Post
    Found this which may help http://www.vectra-c.com/forum/showth...ht=disc+shield. I did post a photo up once but can't seem to find it now. Will keep looking .
    EDIT - found it, definately worth a look just to rule it out. http://www.vectra-c.com/forum/showthread.php?t=47958
    Ashington, Northumberland
    There doesn't have to be play to signify a polaxed wheel bearing. If the bearing is dry but not worn, then it will be noisy
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    my money would be on the bearing m8
  1. fclunking noise coming from front drivers side wheel
    By dti owner in forum Vectra C / Signum Troubleshooting
    Last Post: 24th February 2013, 17:15
  2. high pitched noise
    By drivemyvectra in forum Vectra C / Signum Troubleshooting
    Last Post: 19th May 2011, 16:40
  3. high pitched woosh noise when letting of
    By daveypower in forum Engine & Drivetrain
    Last Post: 5th April 2011, 19:07
  4. high pitch squeal coming from front??
    By KevinG in forum Engine & Drivetrain
    Last Post: 28th February 2009, 17:42
  5. High pitched whinning noise.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 11th October 2008, 16:00
