Thread: Replacement for Estate Space Saver
    New Member Black Maria's Avatar
    Cheshire
    Default Replacement for Estate Space Saver
    Hi All,
    I know the estate doesn't have enough room for a full size spare alloy but has anyone succesfully managed to fit a steel wheel with a narrower tyre under the estate floor cover?
    I've just moved to the Vec C SRI from a Mazda 6 TS2 Estate (which took a full sizer under floor) and hate not having a full size spare.
    Any help much appreciated.
    Cheers.
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    I have an estate aswell, I think the spare is a 16", can't see why a 16" alloy wouldn't fit though.. I was under the impression it was only cars that came with the 19" factory wheels that had a steel spare and not another alloy becasue of the width of the wheel ie: to take a 235mm tyre...
    might be wrong though..
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    there fit nicely a 215/55/16 tyre downthere (just remove the plastic in the buttom then it can be there.. no problem.. maby even a 235...)
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    TO Kenp.
    Are you sure that you are talking about the estate and not the normal hatchback? I had a 2.0 DTi estate that had 16" tyres on it and a spare steel wheel would not fit into the space where the space saver was, even with the plastic spacer removed.
    The other 2 estates have been the same (17" wheels).
    BUT the hatchback and sallons would accomodate a full size spare wheel.
    Cheshire
    How daft were VX when they designed the floor of the estate and didn't make the wheel well big enough for a full size spare. My 17" alloy makes the estate floor sit miles in the air and that's no use to man nor beast.
    My plan is to aquire a steel wheel probably 16" and fit a tyre which will be narrow enough to let the floor sit down flat but still give the same rolling diameter of the 17" alloy and tyre.
    Just thought I'd ask here to see if anyone had done it this way.
    Cheers for the replies.
  1. Space Saver
    By cameraman in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2009, 08:21
  2. space saver replacement
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 18:30
  3. Space Saver
    By Ben H in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2006, 09:14
