Results 1 to 3 of 3
Thread: Wet carpet in footwell
    Regular Member s1nglef1sh's Avatar
    Fife - Scotland
    Default Wet carpet in footwell
    I was cleaning the interior the other day and noticed that there was a big wet patch on the carpet behind the drivers seat.
    I'm going to check out the seal and the quarter window as advised in the threads I've found on here. Also the spare wheel compartment in the boot.
    What I'd like to know is whether Signums are known for corrosion underneath? Could the water be getting in this way?
    Blidworth, Notts
    I have had this problem on my Vectra and on a friends. If you open the bonnet and look at the plastic cowling that surrounds the window wipers on the passenger side. There is a cutout, lift it up and put your hand down in the rubber drain. It's probably full of leaves and gunk. Remove leaves and all should be OK to stop footwell filling up.
    Hope this helps.
    Regular Member signum junkie's Avatar
    Edinburgh
    My problem was def the rear quarter window panel and VX did own up to knowing it was a problem .
  1. What are these on the carpet?
    By weidass in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2012, 12:15
  2. carpet
    By rave5 in forum General Chat
    Last Post: 2nd January 2010, 00:39
  3. car carpet
    By neverlandandy in forum General Chat
    Last Post: 25th March 2009, 13:41
  4. carpet
    By bigron1988 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2009, 17:51
  5. Carpet mat set Vec C
    By blue estate in forum Parts for sale
    Last Post: 19th March 2008, 22:31
