Thread: Brake discs
    Chelmsford
    Default Brake discs
    Just had my cambelt changed and asked the garage to take a look at my brakes (been a while since pads were changed).
    They confirmed that the pads are low, but also said the discs are going to need replacing soon too. I'm a little surprised as the car has only done 53k, but I trust the garage as they knew that I was planning on doing the work myself.
    Is this about right for a new set of discs? Anyone got a price for a pair?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    For the cost that VX stealers charge for a disc and pad kit (parts only), it's not much more than buying VX pads on their own. At this sort of price (£70-£80 for fronts IIRC), the discs work out really cheap - cheaper than buying discs and pads separately.
    Someone on here should be along with prices and part numbers .
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    IMO 53K miles is not good for discs to be worn out. Mine are at 103K and still in good shape.
    [Ex]Admin Duncan's Avatar
    Your front discs are on 103K and not needing replaced? You are allowed to press the brake pedal to stop ya know!! lol
    Seriously though, how? I assume practically all of your driving is on motorway then?
    DNS - as gtr said you can get the Vx disc and apd set for around £65 if you were up to fitting them yourself.
    Plymouth
    I always thought that discs would need changing roughly around 40-60k for mixed driving and 20-30k for purely city driving (like taxis)
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, most of my driving in on M-way - - - that's why I get long tyre life, long pad life (over 75K) and full service intervals. I'm not a heavy braker either (unless I have to be of course) - -although I did have to change my rear pads that had only done 26K - cos the caliper to hanger spring had pinged out and the resulting misalignment caused uneven wear to the pads on that side, but the other side were fine with plenty of pad left....
    Car sympathy means longer life.
    Chelmsford
    Blimey, 2 discs and a set of pads for £63+vat! Local dealers have them in stock! I guess that's where I'll be off to as soon as they've finished the cambelt...
  1. Brake Discs
    By WilliamLX in forum Handling & Braking
    Last Post: 23rd September 2010, 18:09
  2. What brake discs??
    By DaMan1000 in forum Suspension, Wheels & Brakes
    Last Post: 22nd April 2010, 20:04
  3. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  4. Brake Discs
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2007, 10:55
