Results 1 to 10 of 11
Thread: Hid question
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default Hid question
    guy i have the hid kit from HIDS direct and in the manual it says to have a 20amp fuse for the lights. has anyone done this or is it 20amp already?
    Regular Member P3tchy's Avatar
    Milton Keynes
    The lights are fused through the main fuse box anyway.
    Aug 2007
    Lisburn, N.Ireland
    i think it means to replace the fuse in the fusebox to a 20amp one. do you think i needs done?
    Milton Keynes
    I didnt replace mine, Got a 35w kit fitted which is actually less of a current drain than the standard H7 bulbs.
    Aug 2007
    Lisburn, N.Ireland
    i got the 50w set. just noticed it in the instructions so thought i would wait and see if anyone had
    Belfast
    I'd not problems with mine off whatever the fuse is. Though I did see something with the 50W HIDs that the startup current is heavier than the standard 35W ones.
    Personally I'd run a relay, as long as you have a set of warning canceller things to plug in to the light. Tie the relay sense line to the canceller, should work a treat.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Haven't changed my fuse and i have a 50w kit
    Regular Member Robbie69's Avatar
    Quote Originally Posted by bigmac View Post
    Regular Member blues n twos's Avatar
    Seer Green, Bucks
    I have 50w and no fuse changed and no probs.
    Jon
    Regular Member MightyCris's Avatar
    Aug 2007
    Constanta, Romania
    I have mounted several 50w kits (on Veccy, on Astra H, Audi A4, BMW320) and they work well whitout changing the fuse; if there was a problem I think they probably wouldn't have worked at all from the beggining.
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
