Results 1 to 10 of 13
Thread: 3.2 V6 - How Many Sparks Per Rev
    Regular Member marcdale's Avatar
    May 2006
    Bristol
    Default 3.2 V6 - How Many Sparks Per Rev
    Hello!
    Just messing around with my LPG system and came across some settings for ignition types.
    Can any one tell me for definate if the ignition system on the 3.2 V6 Petrol sparks once or twice per rev?
    It will help me get the correct ignition timing for my gas system.
    Full Member Big Sig's Avatar
    I would have thought that for one rev of the engine it sparks 6 times - once for each cylinder?
    May 2006
    Bristol
    I see where you're going, but I meant per cylinder. I should have made that clear, sorry. Some coil packs fire twice per rev per cylinder, probably to ensure good spark or burn any left over fuel, who knows. It probably happens so quick it would like one spark anyway.
    Anyone got a haynes that might tell us? Any one on here who really know their stuff when it comes to ignition systems?
    Regular Member Vauxhall Thru & Thru's Avatar
    May 2008
    Nottingham
    Quote Originally Posted by marcdale View Post
    I don't know categorically, but I would say once per rev. Sparking twice would reduce the life of the units, and I doubt that Vauxhall would design it this way?
    Maybe one of the gurus can help?
    May 2008
    Tyneside
    A four stroke engine only sparks once every two revs. The camshaft only rotates at half engine speed, hence when doing the cambelt you rotate the crankshaft twice to match up the timing marks on the camshaft when checking. Remember suck, squeeze, bang, exhaust - four strokes.
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    It's true that you only need one 'bang' in your suck, squeeze, bang, blow cycle per cylinder but many engines have a 'wasted spark' setup. For ease of manufacture and design they spark at the top of each stoke but at the top of the exhaust stroke it has no effect and is therefore 'wasted'.
    Mileage : 55000
    As said above..From what I understand too. They spark Twice. Once to ignite the fuel and a "wasted spark"( I don,t think it is as strong as the ignition spark) to ensure all the fuel is burnt before it is sent into the exhaust ( unburnt fuel will damage the cat).
    May 2006
    Bristol
    Default Thanks VXVirgin and Ed Taylor
    I thought this might be the case. I know the obvious answer being 1 spark = 1 bang but with modern ignition systems there's a lot more to it.
    I also understand that modern fuel systems can some times open the injector twice per rev per cycle as well. Once for the bang you expect, the other is sometimes used for extra cleaning or lubrication and some times it use in conjuction with butterfly valves on the intake to 'pre' deliver a small amount of extra fuel to the cylinder in time for the proper amount of fuel arriving at the correct time in order to give you extra power.
    I certainly see this on the V6 petrol, you get to a point in the rev range and then there's a kick and it's got an immediate increase in power. This is most likely helped with the mentioned extra injection of fuel at the point the intakes spring open fully.
    Things aren't as simple as they used to be!
    Thanks anyway!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The only people to truly know how many sparks per power stroke would be the product engineers for the FIE.
    Modern diesel can do 5 injection events per power stroke, but most only do 3 - Pilot to warm, Main charge, and post to clean things up.
    Maida Vale
    The 2.5 and 3.0 V6's in the Omega definately use the wasted spark system...as the 2.6 and 3.2 are developments of these I think it's highly likely they do the same.
  1. New coil pack and sparks yet still some throttle hesitation.
    By "First Veccy" in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2012, 08:51
  2. Gsi 3.2 v6 Sparks plugs
    By Spelly in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2006, 18:00
  3. Need Good Sparks&Leads........
    By sparky71a in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2006, 00:49
