Thread: Has any one replaced the lower aluminium arm bush
    Regular Member Teza's Avatar
    Feb 2006
    west midlands
    Default Has any one replaced the lower aluminium arm bush
    Has any one had to replace the lower aluminium arm Bush.
    Is that what it is the part the spring sits on at the rear of the car ?
    The bush has worn at the top as you look at it, the side where it connects to the hub. Looks like a metal sleave is starting to show
    Any one know the part number & how easy it is to fix (looks easy)
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Am a bit confused???? Do you mean the lower control arm or the auxiliary control arm or the upper control arm??? pics???
    Feb 2006
    west midlands
    Quote Originally Posted by carpet View Post
    no i forgot to take a pic my phone rang & got side tracked
    Its the same as this part on ebay, Vectra C Signum Rear Suspension Lower Control Arm Item number: 260286094274
    Jul 2006
    TENTERDEN KENT
    I think that you will find that the lower control arm is pressed steel. To replace it first remove rear spring, remove outer bolt then inner bolt (only two holding it in place) but remember to mark the position of the toe-in adjustment eccenntric disc on the inner bolt. They suggest new bolts.
    Feb 2006
    west midlands
    cheers mate
  1. Rear suspension bush (lower) How do I change it?
    By Big Dave in forum Suspension, Wheels & Brakes
    Last Post: 2nd December 2016, 12:41
  2. For Sale: Aluminium footrest
    By n8sby in forum Parts for sale
    Last Post: 25th January 2013, 19:14
  3. Vectra C Rear Lower Arm Outer Bush
    By Mark-R in forum Suspension, Wheels & Brakes
    Last Post: 29th December 2012, 19:58
  4. rear lower control arm bush
    By Phil in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 13:32
  5. Aluminium
    By Messenger in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2009, 02:51
vectra c outer hub bush site:www.vectra-c.com
vectra c outer hub bush part number
