Results 1 to 10 of 23
Thread: Pulling to Left
    Plymouth
    Default Pulling to Left
    The car keeps pulling to the left when you are going forward and u let go over the wheel.
    Tracking has been checked and is ok... so what else could it be?
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Tyre wear mate Im getting the same mines pulling to the right
    Im buying new tyres over the weekend as there worn on one side which is making it pull
    Club-Vaux Admin
    Engine : 1.9 cdti
    Mileage : 145k
    mine pulls to the left too but so did my last vec so i just thought it was a vectra quirk ...
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    The tracking probably ain't been set up properly. Did the garage check that the rear wheel set up was perfect before they set the fronts?
    As most common or garden tracking gear uses the rear wheels as a datum, incorrect rear settings = incorrect front settings.
    Ideally, you need a place like this in the South west. http://www.wheels-inmotion.co.uk/steeringgeometry.php. Also have a read of some of their "technical theory" for an insight into all manner of steering related problems.
    If your front tyres aren't rotional, try sawpping the n/s front for the o/s front or swap the fronts for the rears and see if the problem persists.
    Plymouth
    the vx dealer said they looked at the tracking but it was a ok... then they looked puzzled when i asked what it was!!
    I will look at the tyre wear and see if thats suspect.... but the steering wheel itself is turned left by around 5 to 10 degrees..
    If its the tyres u reckon i will have a chance getting the vx dealer to change them for sod all seeing as i bought the car there less than a week ago?
    Apr 2008
    Liverpool
    Mate is it when your driving your car actually turns left?
    As when I had my tracking done my Streering wheel was right 10 degrees and the car was driving stright
    but if yours is pulling left It very well could be the tyres
    Plymouth
    Quote Originally Posted by Sean-2.2Direct View Post
    Yeah u trundle along on a straight road
    (the faster u go the faster it pulls left)
    The steering wheel is perfectly aligned for going straight... but if u let go something pulls the steering wheel to the left.. and off into another lane we go!
    Apr 2008
    Liverpool
    Have a good look at the inside of the tyres mate its looking like it might be that check for un even wear and let us know how your getting on
    Plymouth
    Ok had a look..
    Fronts are even wear.. about 6ish mm all over
    Rears...
    the passenger side is down to 3-4mm all over (NCT5)
    The drivers side is a diff tyre but is pretty new at 7-8mm (Bridgestone N3000)
    Apr 2008
    Liverpool
    hmm im not sure then someone else will be along shortly that will know more on that pulling at least you know its not tyres and tracking now
  1. Pulling to the left.
    By blackveccyC in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2012, 00:23
  2. Pulling to the right, then left.. Help!
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 18:06
  3. Pulling to the left
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2009, 21:52
  4. pulling to the left
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2009, 19:51
  5. Car pulling to left
    By andy1103 in forum Suspension, Wheels & Brakes
    Last Post: 1st January 2009, 22:52
has my vectra c 1.9 tracked but pulls to the left
