Thread: Q about Wheel nut tension
    Regular Member mohojo's Avatar
    Canberra, Australia
    Default Q about Wheel nut tension
    I have a 2004 Holden Vectra CDXi and the owner’s handbook says, under the maintenance schedule, that every 15,000 km or 12 months (whichever occurs first):
    “Wheel attachment – loosen and tighten to torque 110 Nm”.
    I was wondering if someone could please enlighten me as to why this should be done? Will the wheel fall off it’s not done, or is this just a Holden scam? Does Vauxhall make the same recommendation?
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Probably to stop the nuts from seizing up
    Probably as above is a reason, and also it's best to loosen a nut before tightening it so that you can get the correct torque.
    Vx have the same in their manuals. You don't need to get them to do it, if you take your wheels off yourself often enough for any reason, then a torque wrench would be handy to have anyway.
    Canberra, Australia
    Thanks guys. That makes sense. I will invest in a torque wrench.
  1. Replace toothed belt and tension roller guide.
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2013, 12:58
  2. tension pullys come off
    Last Post: 29th April 2011, 18:47
  3. Cambelt tension
    By melvin in forum Engine & Drivetrain
    Last Post: 27th October 2010, 15:22
  4. Clutch Return spring tension
    By Dazbaz in forum Vectra C / Signum Troubleshooting
    Last Post: 20th January 2010, 12:54
  5. Timing Belt Tension 1.9 120bhp TDI
    By jimboy26 in forum Engine & Drivetrain
    Last Post: 28th June 2009, 18:59
