Thread: Gearbox or Clutch knackard?
    Falkirk
    Default Gearbox or Clutch knackard?
    Okay, just heading out to work there, got out of the street and about 300 yards up the main road when the car felt like it popped out of gear. I try dropping a gear (from 4th to 3rd) but it did nothing, was just like the car was in Neutral. eventually rolled to a stop at the side of the road and although it feels like its going into gear (the reverse lights come on etc), it's still like the cars in neautral.
    Any ideas what the problem is? The cars a 2004 2.0 DTi Vectra with 75K on the clock.
    Cheers Guys.
    Jay
    Plymouth
    does it feel like it goes into gear when the car ir running??
    if so..... id suspect the gearbox
    Surrey
    Sounds like the box to me.
    EVERYWHERE
    It could be that the linkages have come adrift from the gearbox.Does the clutch feel the same?
    Falkirk
    Yeah, it feels like it's going into gear, had a look under the bonnet and the linkages seem okay, they move as you would expect when I run thru the gears. Have now noticed that the gearbox is making a grinding noise when I pu it in gear so def sounds like the box is away.
    Now I need to find out if the box can be repaired or if it needs a new one.
    Anyone got any idea what gearbox is in the 2.0 DTi?
    Cheers.
    EVERYWHERE
    Quote Originally Posted by Jayz Vectra View Post
    Cheers.
    2.2 DTI has F35 gearbox I think.Not too sure about 2.0,but probably it's the same.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    if you need a box would this one fit as its cheap
    http://cgi.ebay.co.uk/VECTRA-F23-GEA...1%7C240%3A1318
    just a thought m8
    EVERYWHERE
    That's an F23 which is not capable of handling the torque from even the 2.0 DTi.Come to think of it,the F35 doesn't seem to be able to do it either! LOL
    Falkirk
    Quote Originally Posted by big rich View Post
    just a thought m8
    Cheers dude, was raking thru Ebay all morning for a Gearbox but didn't know which one I needed!!
    Quote Originally Posted by diesel dog View Post
    Think your right there! My mate has a 2.0 DTi too and he's on his 3rd gearbox! Mind you, the car has nearly 200K on the clock.
    Anyhoo, just to update, I got a friend to tow me [using his 1.9 CDTi Signum - fantastic car!] to a gearbox specialist. He put it on the ramps straight away and said the clutch and gearbox are okay but the driveshaft has popped out of the gearbox. He's gonna strip it down and double check everything else is okay then build it back up again. Hopefully a cheaper fix than originally thought!
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Nice one mate hope it is only a drive shaft sounds plausible with the symptons.
  1. gearbox and clutch
    By vectra craig in forum Engine & Drivetrain
    Last Post: 13th June 2012, 19:50
  2. Gearbox & Clutch Faliure?!
    By mattster87 in forum Engine & Drivetrain
    Last Post: 3rd September 2011, 16:38
  3. Clutch?? Gearbox??
    By wingz123 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th March 2011, 10:47
  4. New gearbox and clutch
    By 2.2direct-sri in forum Engine & Drivetrain
    Last Post: 21st July 2009, 13:52
