Thread: CD30 mp3
    London
    Default CD30 mp3
    Hi guys
    Just got my 1.8 Sri which has the CD30 head unit. My understanding is that there is a mp3 version. I've seen a couple on Ebay but they are not specifically for the Vectra. Most of them are from Corsa's or Zafiras. Will these fit my model and if so is it an unplug and plug install jobby?
    Regular Member P3tchy's Avatar
    Milton Keynes
    Depends on the year of your veccie I think mate.
    London
    It was registered in 2008
    The replacement (if 2nd hand) will have to be divorced from the car it was removed from (called put back into delivery mode) and then would need marrying up to your car via a tech2 code reader.
    [Ex]Admin Duncan's Avatar
    If it's not done that way then the unit will be useless.
    Only if the unit and paired display have been removed together from the donor car do they not need Tech 2d out, as long as they are then both being fitted into the recipient car.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    IIRC the Astra version of the CD30 has an angled faceplate too which might look a bit out of place on the flat dash of the Vectra/Signum, not sure about the Corsa version though.
    London
    thanks guys I will try to get a part number and source one.
    Regular Member Vecmaniac's Avatar
    Oct 2007
    Morpeth, Northumberland
    ON ebay a while back and some bloke from Germany was selling them for £129... here's the link (They're now £164) http://cgi.ebay.co.uk/Blaupunkt-Radi...1%7C240%3A1318
    London
    Nice one, but will that model fit my vehicle? Mine is a sri 1.8 2008. If so how does this tech2'ing thing work? Is it a DIY job or do I need to take it to be reset/married?
    Thanks again
    Oct 2007
    Have to say you've got me there!! Mines a pre-facelift.
  1. Fitting Parrot MKi9200- Can it run through CD30 aux?(does CD30 even have aux!?)
    By dibble750 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2013, 02:20
  2. Quick CD30 to CD30 MP3 question
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2012, 00:47
  3. Cd30 & bid
    By KyleSxi in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 15:50
  4. CD30 to CD30 MP3 Conversion
    By yysnet in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 00:20
  5. Replacing CD30 with CD30 MP3
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2007, 13:38
