Results 1 to 10 of 29
Thread: fuel filter 1.9 CDTi
    member of the smoke patrol 230bhp+
    Default fuel filter 1.9 CDTi
    anybody chage the fuel filter on the 1.9 CDTi if you have do you know what you did
    i.e did you just fill the fuel filter up and replace it and it started and has been fine or was there somthing you needed to do to get your car to run after the filter change
    Hi Chris I think there was thread a few days ago relating to this question. As I recall it needs filling or an air lock gives you problems. I'm not a diesel person but hope this helps.
    cheshire
    changed my fuel filter every 12000 miles with no problems on a 57 plate
    Regular Member mattolly86's Avatar
    oxfordshire
    i did mine a few 1000 miles ago fill it up make sure its tight and start as normal
    Regular Member rosssri's Avatar
    S.Lanarkshire
    What have you found is the best way to tighten the filter housing after changing the filter? On both occasions it's taken 2 of us with a pair of oil filter clamps/grips each too tighten it properly. Surely there must be an easier way to do this anyone?
    hull
    I did mine and just turned ignition on so pump kicked in turned it off and repeated it 3 times, this filled up the strainer. Best to have some diesel in there to be safe though. If its anything like mine its a pain in the arse to open. The part you undo says its to be tightened to 30Nm but mine was way tighter so was the replacement I had to buy.
    oxfordshire
    Quote Originally Posted by rosssri View Post
    i just went nuts on my own with 2 oil filter strap wrenches lol and believe me it was way tighter than 30nm!
    S.Lanarkshire
    Quote Originally Posted by mattolly86 View Post
    I thought about this but thought i'd probably end up breaking the housing.
    hull
    My brother did the same but with a oil filter chain wrench!! Snapped the mounting then when he got top off it wouldnt go back on properly so had to get new one. Dealers wanted £102.04 (wasnt happy about 4p) got one from scrappy after a week for £30 posted lol
    cheshire
    best way to change the filter is to remove the housing completely or you run the risk of breaking the filter housing brackets
  1. Oil and fuel filter 1.9 cdti 150
    By chay6684 in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2012, 08:07
  2. Where is fuel filter on 3.0 V6 cdti
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2011, 17:29
  3. fuel filter cdti 150 .
    By dave r in forum Engine & Drivetrain
    Last Post: 14th April 2010, 20:22
  4. cdti fuel filter
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 19:23
  5. Cdti Fuel Filter
    Last Post: 11th June 2008, 22:14
vectra c 1.9 housing
https:www.vectra-c.comforumshowthread.php68806-fuel-filter-1-9-CDTi
vectra c 1.9 cdti fuel filter replacement
fuel filter block on my vauxhall vectra
fuel filter replacement vauxhall diesel 1.9 cdti
2008 vectra 1.9 diesel fuel filler replace
fuel filter housing 1.9 cdti vectra 2005
starting car after fuel filter change vectra c 1.9cdti sri
