Results 1 to 10 of 30
Thread: Boiler problems any ideas?
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Default Boiler problems any ideas?
    Looking for some potential problems so i dont get fleeced basically
    the boiler in the house i assume is over 10 years old certaintly not a new spanking one.
    Problem is it cuts off
    the pilot light is on all the time as it should be and the system is charged up with the right amount of water too.
    itll fire up for 4-5mins and the radiators get hot then before i know it there cold again and the pilot is on and it wont refire.
    Any ideas what part it might be or is it new boiler time
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is it a standard boiler with hot water cylinder in the airing cupboard? If the pilot light goes out, then it is usually the thermocouple gone south, so the boiler thinks the flame has gone out and turns off the gas - so as to not fill the house with gas if the flame had gone out.
    You can get universal ones from B+Q etc for about £5 and they take about 15 minutes to fit.
    They come with a thin copper 'tube' that connects to the control unit, the easiest way to get the routing when replacing is to tie a piece of string to the old one and remove, leaving the string behind between the control and the tube exit near the burner pilot, then tie the string to the new one and pull and feed the copper tube back to the control unit. A simple clip holds the TC in place in the pilot light flame.
    What make and model?
    If it's a pressurized system can't help but the traditional gravity feed could have an air lock. Try after you have the pump switched off, bleeding the rads & any air vents in the loft or a high point in the system as it could be ‘air locked’, try this first Hope this is of some help.
    Plymouth
    it could be a few things... my folks had the same symptons as u and it was a thermostatic valve that needed replacing.
    Aug 2007
    Great Wyrley
    Thanks Ste
    Its an Optima Ferroli or Ferroli Optima
    There is not hot water cylinder in the house it all comes direct from the boiler it has 3 setting continious hot water and central heating/ Timed H water and heating/Hot water
    Im not an expert at all as this is my first house so not sure on anything. however the pilot light is on, then itll fire up and radiators get hot then itll drop back to pilot light and the radiators get colder
    Quote Originally Posted by Ste View Post
    Like he said any easy job as long as you know what the thermocouple looks like. If it is this pick up two & keep one as a spare. It's always the coldest day of the year it packs up.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Oh, i thought you meant the whole thing (inc pilot) went out.
    Forget what I just said in that case.
    Sounds like it is over heating to me for some reason. Is the hot water working on it's own?
    Aug 2007
    Great Wyrley
    yeah hot water works fine on any of the settings
    it literally just cuts off the heating system and the pilot light remains on
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Puzzling then....
    Aug 2007
    Great Wyrley
    Yup, ive tried everything from bleeding all rads to slightly over presurising the system ive cut the pilot light and reset and it will work for 3-5 mins then itll stop and go back to the pilot light
  1. Boiler sorted !
    By bembo449 in forum The 'Off Topic' room
    Last Post: 22nd July 2011, 22:23
  2. problems with my hid kit any ideas
    By danielsmith in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2011, 20:29
  3. Combi Boiler!
    By djr69uk in forum General Chat
    Last Post: 5th March 2011, 02:04
  4. Duff Boiler.....
    By macdad in forum General Chat
    Last Post: 23rd February 2008, 21:38
  5. Boiler Advice
    By leeds vectra in forum General Chat
    Last Post: 9th February 2007, 00:47
