Thread: Air flow meter/engine emissions light
    Regular Member addyboy1982's Avatar
    Northampton
    Default Air flow meter/engine emissions light
    I took my car in a couple of days ago because it was in limp home mode and the dash showed emissions warning light on as well as the spanner light. The fault code that came up was the air flow meter which I have now replaced. The car is running better (but not perfect) but the lights are still on, do I need to get the faults deleted or will the ECU re-set itself after a few turns of the key?
    Ad
    Regular Member vectra666's Avatar
    manchester
    i think u need to get the fault deleted or disconect bat for 30mins.
    Northampton
    I've disconnected the battery for an hour or so but no difference so think I may have to go and get it plugged in and deleted
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You will probably have an EGR or boost pressure fault logged
  1. air flow meter
    By bulldogblu in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 12:44
  2. Air flow meter ??
    By craig-k in forum Engine & Drivetrain
    Last Post: 12th July 2009, 17:11
  3. air flow meter? 1.8 16v sxi
    By kev bux in forum Engine & Drivetrain
    Last Post: 9th March 2009, 23:00
  4. air flow meter
    By Morephun in forum Engine & Drivetrain
    Last Post: 13th October 2008, 19:42
