Thread: Alfie 09
    Cornwall
    Default Alfie 09
    Had the engine management fault light on my 06 Signum, took it the dealers and they diagnosed the ERG valve which they replaced for £211, a common fault they said, too right, 140 miles later on the M5 the light comes back on and I lose power, this goes on all the way to work, another 200 miles, anyone know what else could be wrong ?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Need a code reader to know what has happened.... Did they fit it correctly? When was your car registered? As 06 sounds like still in warranty. Mileage ?
    Sheffield
    I had my 04 - Vectra 2.0 DTI plugged in last week and it showed two P0400 errors, EGR Malfunction, I decided to take off the EGR, it was coated with about a 1 mm of carbon inside and on the valve bulb
    I put my finger in the hole that the EGR came out of and fondled up into the rectangular hole that the exhaust gasses come through and could feel loads of carbon, it felt pretty blocked, I decided to take off,(i think it is the manfold) it is directly above the EGR valve, well it is on mine, it has 4 torque bolts, a gasket and a fat rubber hose attached. I could not believe the amount of carbon and tar like crud that coated everything inside the holes, there is like a dip in the casing that lets gases come through into the EGR valve and that was full, basically blocking the hole the gases should go through. It was dead easy, I used a whole tin of carb cleaner and about five wraggs.
    Sorry I didnt take any pics
    Hope this is usefull
    s.wales
    hi i had exactly the same today not sure if i cleaned it enough it was jammed then freed it,tonight same thing and same code,did yours help
    Sheffield
    Hi I just cleaned mine, I didnt try to release the valve, the light is still coming on. I will probably try and release the valve but I dont want to break it. I have bitten the bullet now and ordered a new EGR.
    C@rlos
  1. Alfie 09
    By Alfie 09 in forum Introduce yourself.
    Last Post: 29th January 2009, 10:04
