Results 1 to 10 of 11
Thread: Could it be my upper control arms ?
    Regular Member Teza's Avatar
    Feb 2006
    west midlands
    Default Could it be my upper control arms ?
    Will wearing of the bush's cause my wheels to sit on a slant (bottom pivoting outwards)
    Took the car to a garage today & they say it could be the lower control arm needs adjustment ? its not fixed yet as they said its not something they do.
    Any advice please
    Birmingham
    Dont know for sure, but the best way to check if your upper control arms have gone is to pull your wheel towards you by sticking both hands into the wheel arch and pulling at the wheel from the top inside. HTH!
    Bye bye Vec B
    - Hello Siggy!
    Feb 2006
    west midlands
    Quote Originally Posted by Vaux-Man-G View Post
    Thanks Just had a go & the wheels do pull outwards with some force. so is that a yes I need to replace the upper control arms. & will any other parts need adjusting, like the lower control arm ? as a garage wanted £50+vat to do. Thanks for your reply
    Birmingham
    Quote Originally Posted by Teza View Post
    To be honest, I would probably say yes, I remember when I tried mine, when they were pulled towards me there was a probably a couple of "mm" movement and like a metallic clunking sound.
    When I changed mine, I did them as I was getting a horrid thudding sound when on even roads, so I changed the arms and the ARB bush's at the same time to ensure I cured the problem first time round, rather than opening it all up again and again.
    TBH, I dont think that £50.00 to change the arms is all that bad, I did mine myself with the help of my dad, but if you dont want the hassle, I would say £50.00 is quite reasonable. It took us about 4-5 hour's to do both sides arms and bush's.
    I bought the arms off ebay and they cost me just under £58.00 delivered to my door for the pair. Vx were more than double this!
    Before you get set to change them, I would wait for a reply off someone on here as to why your wheel is leaning outwards from the bottom, I dont think this is the arm's....so better to get it all done at once rather than again and again!
    Where abouts are you in the West Mid's?
    Best of luck!
    Bye bye Vec B
    - Hello Siggy!
    Your rear wheels will naturally have a bit of toe-in (top of the wheels slanting in more then the bottom) - that's how it's meant to be. It'll also be more noticeable on a car that's lowered, which your SRi will be as standard.
    Feb 2006
    west midlands
    Best of luck!
    I'm in coventry. Got the car booked in to do the wheel allignment & adjust lower arm, but not sure its going to cure the problem.
    cheers
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    my 60mm lowered calibra was the worst for that....it looked the the rear axel was nackred ...but it is completly normal
    Feb 2006
    west midlands
    The passenger side looks more slanted than the other side. The garage said to get the lower arm ajusted first then if no good it could be the upper arm. He had a look but said it looked ok, an it would be a dealer only part. but i have seen them on lmf & ebay so i don't think he knows a vectra c to well. just trying to save some money as i don't want to pay for something that don't need doing. :-)
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Exactly as Duncan has said . Have a read of this http://www.wheels-inmotion.co.uk/tech-camberbasics.php and then get the camber angles checked. Sounds like one wheel is carrying more camber than the others. My 67k 02 GSi had wildly different camber angles before they were checked. Now all is as it should be and the handling has been transformed.
    Birmingham
    Tez, just to be on the safe side, why dont you take a picture of both side rear's from the same or similar angle and let the guy's on here comment. Best way IMHO as you can be more clearer about it then! HTH!
    Bye bye Vec B
    - Hello Siggy!
  1. Upper control arms
    By BigWilko in forum Suspension, Wheels & Brakes
    Last Post: 28th December 2012, 18:47
  2. upper control arms
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2012, 18:55
  3. For Sale: Upper Control Arms
    By Danger_MouseUK in forum Parts for sale
    Last Post: 5th August 2012, 17:15
  4. upper control arms
    Last Post: 7th May 2012, 14:22
  5. rear upper control arms
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 24th October 2008, 18:29
