Results 1 to 2 of 2
Thread: Noisy Aux belt on cold start 2.0T
    Apr 2008
    Nottinghamshire
    Question Noisy Aux belt on cold start 2.0T
    Hi all , could do with some advice , for the last few weeks when I start the car from cold I have a ( hard to describe) squeaky / rattly noise coming from the area of the aux drive belt. Once the engine is warm it is fine. I had a look and the belt is not slipping so I tried a quick squirt of WD40 at various points to see if it was alternator / ac pump ect but basicly if I sprayed anywhere near the belt the noise stopped for a couple of mins. I suspect the belt may need renewing or the tensioner. has anyone else had a similar problem and if so how did you resolve?? Belt looks fine and car has done 63K.
    And if belt needs to changed it it an easy enough job and is there a how2??
    Neil
    [Ex]Admin Duncan's Avatar
    Yep, it's a pretty common problem on the 2.0T.
    http://www.vectra-c.com/forum/showthread.php?t=38678 - one thread to get you started along with the linked threads off it.
  1. Noisy DMF or Belt?
    By Roswellian in forum Engine & Drivetrain
    Last Post: 15th February 2013, 14:52
  2. CDTI Aux Belt Chirp - When cold or first start only
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 16th December 2012, 23:20
  3. Noisy fan belt
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 08:44
  4. Noisy Aux Belt-any ideas?
    By Croxley in forum Engine & Drivetrain
    Last Post: 2nd January 2011, 00:10
  5. Noisy 3.2 on cold starts
    By jamesr in forum Engine & Drivetrain
    Last Post: 18th June 2008, 19:37
vectra 2.0t aux belt tensioner www.vectra-c.com
noicy aircon opel vectra 2.0t
