Thread: Little DIY project - advice needed..
    Norfolk 'n Good Drives : Signum 3.0 CDTi BHP : 229.8 Torque 344.9lb
    Default Little DIY project - advice needed..
    I'm carrying out a little project for our son's bedroom - which involved a push light - one of these in-cupboard things - mounted on the wall....
    But I want more light out of it and longer battery life - it takes 4 AA batteries - but without much more heat - as you can see the internals include paper and card!
    So I think I should be able to replace the 'bulb' - stange bulb at that - with LED's - maybe a cluster or 5 or 6 around the unit.
    Anyone any suggestions what i should be buying to carry this out?
    The inside of the light.....
    Regular Member Big Davie's Avatar
    Jan 2006
    having a giggle...
    Maybe a new light matey..........
    Cant find one that fits the bill.
    The light needs to be of this size and design - and not mains powered because of the location on the wall, I'm looking at a number of LED options but would rather some confirmation saying - go to maplins and buy these bits....... it would make my life easier and the project come together.
    10 points if anyone can guess what the project may be...
    Wiltshire
    Why not just buy 8 rechargeables? When one set is in the lamp the others can be charging.
    Regular Member greeningr's Avatar
    Jan 2006
    Oswestry
    A quick upgrade would be to remove the paper and replace it with tin foil, this would increase the light output through reflection.
    As for the LED's get a cheap LED torch and use them as they are already configured in a holder that should be easy to fit.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    A thought, is there no way of getting mains power there? Possibly use a AC-DV inverter to lower the voltage to 9v so it is safe (If that is what you are concerned with)....
    LEDs yes would work but emit a strange light. Get to Maplins they have everything on shelf you would need.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Auto lights in the cupboard? Open the door, light comes on. Close door, light goes off?
    Point Winner ???
    As said above, LEDs give a slightly strange light colour. Could you not replace the paper / card with tin cooking foil and replace the bulb with a higher power output 6V one? Maybe even increasing the size of the battery to those with the 2 springs on top and about 2" square and 4" high. These would last a LOT longer and easy to replace without removing the light from the wall. Could the battery be supported up near the light or on a shelf with a thin wire to the light????
    Quote Originally Posted by Ste
    Auto lights in the cupboard? Open the door, light comes on. Close door, light goes off???
    No prize this time..
    I need them to be non mains as they will be mounted a fair way from a socket and I dont really want trailing wires on his walls.
    I would like a brighter light output and understand LEDs only output a small beam, so a series of bulbs would give an even output. I was also planning on spraying the base silver, including the inside of the base.
    Wiltshire
    They would, but you'd have to frig the battery holder to only use 3 rechargeable batteries (3.6V) or use the 6V dropdown resistors they sell to protect them from over voltage, which will fry 'em.
  1. Replies: 2
    Last Post: 26th August 2011, 23:15
  2. Advice/help needed
    By viperone in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2010, 15:48
  3. Help & Advice Needed
    By vectraliam in forum Engine & Drivetrain
    Last Post: 21st January 2010, 16:55
