Results 1 to 10 of 23
Thread: Engine Bay Fuse/Relay Box Query....
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    confused Engine Bay Fuse/Relay Box Query....
    Our 55 reg Facelift Vectra Club has14 relay slots in this fuse/relay box. but only 6 relays fitted...
    Relay slot positions R1 - R5, R10 & R13 are not used, and don' t have female connectors fitted to accept the male connectors on relays...
    Relay positions R6 - R9, R11 & R12 are used with R14 unusedbutfitted with female connectors, I presume pre wired for something, to accept a suitable relay.....
    R6 has a black case
    R7 has a red case
    R8 & R11 have yellow cases &
    R9 & R12 have brown cases...
    so which relay switches what is a mystery...no info in the facelift Vectra handbook (only what the fuses feed) and no symbols on the inside of the fuse/relay box cover....only relay & fuse numbers.......
    I'd be grateful if one of you auto electrical gurus out there can tell me what the they each switch...
    I dont fancy pullin 'em out one at a time to see what doen't work in case I ****** something up with the electronic....
    The Haynes manual refers to various relays in the Electrical schematic section as
    K1 - Starter Relay,
    K2 - Rear Wiper Relay),
    K3 - Terminal 15 relay is listed several times in various diagram...What is/where is this terminal???),
    K4 - Horn Relay
    K5 & 6 - Front Wipers slow/fast & on/of
    K7 - Headlamp washer relay - which I don't have and so its slot will be unused,
    K8 - Central Locking relay (fuel filler cap) &
    K9 - Washer relay....
    Thanks to anyone who responds.....
    Tony
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Aren't the details on the fuse box lid?
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    No Ste...only the Relay & Fuse numbers as mentioned....gonna take some pictures and post 'em to show what I mean....when I've read how to do it...cheers for now....
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    I must admit - I want to know what 14 is too......
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    There must be somebody out there who will take the trouble to a look at the pictures I posted..on a later thread on this subject and comment on my query surely............
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    All I can find is this. Still no answer to the purpose of the relay at position 14
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Thanks for your contribution JagRigger....it's much appreciated...it does throw some light clarifying most of the query I have....still puzzled with the Vxl relay numbers/positions for the twin tone horn system (Mine is only a single tone and appears not to have a switching relay) and the twin spot light relay......Thanks again...
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I'm still looking for the relay list, but here is the fuse list.
    Pre Facelift fuse No
    F 1- spare
    F 2- 30A-air con/cooling fan
    F 3- 40A-rear heated screen
    F 4- spare
    F 5- spare
    F 6- 10A-RH dipped beam/headlight levelling
    F 7- 10A-RH parking light/tail light
    F 8- 10A-RH main beam
    F 9- 30A-headlight washer
    F10- 20A-horn
    F11- 30A-central locking
    F12- 20A-front fog lights
    F13- spare
    F14- 30A-windscreen washer
    F15- spare
    F16- 10A-rear fogs
    F17- 30A-elec windows
    F18- 10A-number plate light
    F19- 20A-fuel pump
    F20- 30A-elec windows
    F21- spare
    F22- 20A-hazard warning lights/info display/trip comp/air con/
    Interior light/cooling fan/infotainment system
    F23- spare
    F24- 10A-LH dipped beam/headlight leveling
    F25- 10A-LH parking light/tail light
    F26- 10A-LH main beam
    F27- spare
    F28- 20A-coolant heating(diesel )
    F29- 10A-hazard lights/elec mirrors/elec windows/sunroof/instruments/
    cruise control/interior light
    F30- 30A-sunroof
    F31- spare(also been known to be the cigar socket worth a look socket not working )
    F32- 10A-daytime running lights(scadinavia)
    F33- 10A-constant supply for tow socket
    F34- 10A-cd player
    F35- 10A-ABS/traction control/auto box
    F36- 20A-air con/heated seats/cigar socket
    F37- spare
    F38- 10A-stop lights/reverse lights/auto trans/cooling fan/
    tid-mid display/cruise control
    F39- 10A-auto trans
    F40- 10A-cooling fan/air con/heated rear screew
    F41- 10A-heated mirrors
    Facelift fuse No as above with the following changes
    F 6-15A
    F13-10A-interior light
    F15-5A-reading lights
    F19-10A-radio/carphone/infotainment system
    F21-10A-infotainment system/select lever lock/central locking/hazard warning lights
    F22- 20A-hazard warning lights/information display/air con/interior light/
    F29- 10A-hazard warning lights/dipped beam/reverse lights/elec mirrors/elec windows/sunroof/
    Instruments/interior lights
    F31- 30A-interior light/instrument illumination
    F33- 20A-constant supply to tow socket
    F34- 20A-instuments/radio/carphone/infotainment system
    F37- 10A-cigar lighter
    F38- 10A-stop lights/cooling fan/information display/cruise control
    Picture of my fusebox
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    Thanks Ste....Info much appreciated......didn't realise the relay I.D. query would be so difficult to address.....If you do manage to any a big thank you for your help anyway.....Tony
    Nov 2007
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    OOps....It should have read..."If you don't manage to find anything further a big thank you anyway......Tony
  1. Relay or fuse
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2012, 19:02
  2. small fuse/relay box?
    By neill in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2011, 18:20
  3. Engine Bay Fuse/Relay Box Query....
    By Tony W in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2010, 18:23
  4. f1 Fuse - possible relay problem!!!
    By az sri in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2008, 02:03
vectra c relay diagram
vectra c front fog light relay location
vauxhall Vectra 2006 cooling fan relay location
vectra c fuse box diagram
vauxhall vectra relay diagram
relay location vectra c
vectra c headlight relay
opel vectra c mikä rele on r6
vectra c relay r14
witch relay and fuse runs the ac on a vauxhall vectra c
vectra c fuse box layout
relay r12 vectra 2005
r14 relay vectra 04
vectra c1 releet
vectra turbo r11 fuse
Relevador R12 R11 R10 del vectra 2004
vauxhall vectra relays diagram
by details opel vectra 2008 fuse boxsopel vectra 2008 fuse box diagramvectra c washer pump relay locationcruise control opel vectra cvectra fuel pump relay locationvectra sri indicatot relay locatuonvectra c starter motor relay location
